Hi Everyone,
I am in the process of buying a R33 S1 or S2 and I am told different power figures that a stock R33 would have. I know that they have 187Kw at the fly and supposedly they lose 18% through the drivetrain which means they should be making 153rwKW.
Then again, some say they have about 120-130rwKW.
If anyone could shed some light on this matter it would be most appreciated as I do not want to buy a lemon....lol
Thanks Heaps.
I think the losses run closer to 30% so 120-130 rwkw sounds about right.
Thanks alot, B0oStEr, for the info.
Other, views or personal testemonies (ie. dyno results) will be very helpfull and most appreciated.
I think our first result was 148kw with with aftermarket panel filter and 3 inch exhaust.
The 120-130 ish does seem about it standard.
El Bee
What type of exhaust and was it a full/cat-back? On what, if any, boost and what type of boost contoller?
thanks heaps.
Nabil,
Now you have jogged the memory a bit (getting old you see).
The exhaust was custom from dump pipe back and I think we had the bleed valve then at about 10 pounds.
El Bee
*edit* No exhaust as posted below
Guest DIRTgarage
OK. I have been corrected by my Wife.
When we got 148kw it was with the stock exhaust.
We did have the panel filter and more boost.
It was on a dyno day using shootout mode on a dyno dynamics.
El Bee
G'day el bee....nothin like confirming things with the good wife.....its amazing what they remember (anniversaries,power outputs etc). See you at WSID next Sunday....hope to meet and say g'day.
Gday Paul, yes it is amazing what they do remember.
My Wife is the oricle of all things memory, especially to do with our Skyline, in this household.
The good thing is she does know "shit from clay" as they say.
I'll see you Sunday. Unfortunately Genelle won't make it this year.
Enjoy!
El Bee
ps. Increasing boost does increase power for sure but you can go too far and easily get into the "rich and retard zone" with the stock ECU.
Have done this before. And last time on a dyno the guy turned the boost down from 14 to 10 and got rid of an ugly dip in power where the ECU was having kittens.
Will have to get an aftermarket ECU very soon. (not before drag day unfortunately)
I thought that the Japanese giants all agreed to limit at 140kw? that is why it is soo easy to get more outa these beasties they're just detuned (small air in small exhaust out) to a limit to meet certain standards.
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
