Hey Mods,
Getting a bit sick of people who come on and post ads offering "phones from $190" blah blah blah..
not sure what you can do about this, it's very hard to mod these people, i'm hoping that you are removing posts and banning them..
apart from that - no ideas/complaints.. just sick of people doing ^^
Links
https://www.sau.com.au/forums/topic/81587-people-signing-up-and-advertising/
we are, fear not.
just remeber the sheer amount of traffic this forum gets. We dont always see things right away depending on who is looking after what setcion etc etc.
you'll notice they get banned (if you check)
it might be a idea to remove their posts so it makes it a futile attempt at advertising.  If their post is still up they're still advertising their product or service.
not that i'm bitching, the mods to a great job :)
we do that too :rofl:
I can see a few mobile phone threads that have been moved to the moderators area right now
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
