Hi All,
Clutch has apparently died in my R32 GT-R so its time to do a switcheroo. Whilst its all apart it might be worthwhile adding a lightened flywheel.
So does anyone have a lightened flywheel for an R32 GT-R (1989 model: can never remember if they are push or pull) sitting around that they want to sell? Alternatively, does if anyone knows of some good deals lemme know.
Lucien.
https://www.sau.com.au/forums/topic/81597-r32-gt-r-flywheel/
Push or pull doesn't matter to the flywheel but for reference the 89 should be a push clutch.
We can supply a brand new Fidanza flywheel which is l/weight ( approx 4.5kg ) alloy with a replaceable steel insert.
It is also a pretty purple and is $660 incl plus freight
Cheers
ken
lucien have you driven a car with a light flywheel on the road? the reduction in torque at low revs is noticable.....
High duncan,
No, I have not had the pleasure, I have only read other people's experiences (which are overwhelmingly positive, but you wouldn't expect them to be too critical of their decision having just shelled out $500+ :huh:).
Does the faster revving, in your experience, mitigate some of the torque loss at low revs? Not worth the tradeoff?
  • 2 months later...
I'm in the same situation at the moment.. clutch needs replacing 'cause it's stuffed and I'm thinking about doing the lightened flywheel at the same time.
Since the car is a daily driver more than anything else I really didn't want to go under 5kg. UAS have one at 6kg but I called them up today and they said they won't have any for a few months (at best).
I can't be bothered waiting that long so I'm considering the option of just machining the stock one down a bit.. maybe shave off a kilo or so. Don't really know what a safe limit is but I'll get someone that knows what they're doing to do it.
Anyone else have their opinions on this?
I bough the car with a stock flywheel in, and changed to a lightened one, got sick of it. As Duncan says driving around town its annoying. Anything under 2,000rpm and my car would shudder... I changed back to a stock flywheel and am glad i did. Car is much nicer to drive with the stock flywheel.
I never noticed a speed increase in reving, but that would probably because i fitted a twinplate with my lightened flywheel, so the twin plate+lightened flywheel probably weighed the same as the single+stock flywheel.
My advice? Save your money, keep the stock flywheel (get it machined if it needs it obviously). Jim Berry told me the same thing - said the Japs usualy get it right with thier flywheels, they are a good weight. Being turbo cars we need to keep the rpm spooling, if it was a torque monstor down low, then maybe consider a lightened flywheel.
Hope this helps.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
