Hey you found your sunnies, and i found my fathers ring i though i lost at the OZ GP...LOL was covered in a bit of blood from hand getting caught on windscreen of car i was bonnet surfing accross, turns out i seemed to have stashed it in the kitchen, probably next to where i was administering first aid to myself. I thought it had rippe doff my finger:(
LONG LIVE THE MESSED UP UNITS:):);)
  • Replies 82
Brisby dont lie u dont regret anything u had an awesome weekend and u sarked a lot of piss... And we all know u cant wait for the next track day to do it alll again... Expensive weekend but damn was it worth every cent...
First up a big congrats to Scotsman - thats an awesome time mate :) So was that in your beast or the dragon? Looks like my words of encouragement at the last meet made all the difference hehehehe :)
Secondly the telstar that can neva loose - Scott how the hell did you manage to pull a 1:41??!! Thats a great time for a skyline let alone a car driving from the wrong end!! Sorry to hear about the dramas you had on the day and I hope to see you out there at the next one.
Lastly, I noticed that the sep winton round had changed dates to Sep 11th instead of Sep 3rd on the wrx website - is this confirmed??
PS Ooops just downloaded the champ. table and it seems chris's time was set in the dragon ;)
Hmmm...$285 of ATM withdrawls from Saturday night, and i woke up in the morning with $50 in my wallet:alcoholic:
lol...what was a round of that sweet nectar worth again:)
hahaha - thats $50 in your wallet was actually under your wallet when I found it in the hallway of the pub on Sunday morning - I assumed it was yours.
And congrats for finding your dads ring!!!
Was the M3 stock though??
Would swap my car(s) anyday for an E46 M3.
of course it was stock, you spend $160k on a car and you shouldn't have to modify the damn thing!
with that said, by now you'd probably swap your gtr for a trabant and a month's supply of kerosene :D
I beleive you can get them on the road for bout $150k :)
As for the swapping, that's enough out of your trap mister. No more smart a$$ comments from you or B A N
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
