  • Replies 82
Hehe - Aaron, what time did you get up? Did Lynne survive?
And to stop the PMs...
Belfast Car Bomb
1/2 pint of Guinness
shot made up of 1/2 Bailies - 1/2 Kahlua
Drop shot glass into pint and scull (taking care not to swallow shot glass)
Repeat as necessary :D
Good work by some of the newbie's - William and Mavric. Matt if you can learn to drive like your teacher in Brisby then we'll all have plently of entertainment to watch in the future.
Im not quite sure if this is a good thing or not... Providing entertainment on a similar level to Brisby think that should be left to the man himself.....
Belfast Car Bomb
I left about 2 mins after Chris left, I had a shower and contemplated eating. that contemplation led to me needing to lay down for a while. I saw Lyn on the way back, in Templestowe so I think she held up ok.
I got MESSED
the JODA's owned me
a JODA is one shot of midori, one shot of cointreau, one shot of galliano and a splash of apple juice. This does not mix well with beers and Belfast car bombs.
Seemed like a bloody wonderful idea at the time though
I seem to remember talking to Cody Crockers godmother?
WARNING _ BIG POST_!
For those of you who care, or those of you who don't, the following can be found in my new book:
"How not to retrieve a Vehicle, in 10 easy to follow steps".
Chapter 1.) Only 9.5hrs return trip!
Left Benalla, and got home about 2.30. Left home at 3.
The trailer had an awful vibration, be disappeared at 80km/h. I saw a sign for hot donuts and pulled over. Checked the trailer, and smelt rubber. So I checked each tyre. One was ballooned a little, and was farken hot to touch. Let out some air. Get donuts and boot off.
about 30 mins later, I had a retread tyre on the trailer delaminate, so it had about a 1/4 of the tread missing. Fortunantly it happened 1 km from a rest stop. Limped it into there. go to change the wheel, and had the wrong sized wheel brace. needed a 19mm, I had a 17mm. (later found another one in the car that was 19mm).
So.... I Stood around ready the break something. Couple pulled up into the rest area. They had a Falcon. (19mm lug nuts). Asked them to use there wheel brace. Got The wheel off. After Undoing the bolts holding the spare to the trailer, found out that the spare was stuck to the trailer. Had to bash it off.
An hour or som later, We arrived in Benalia. I lined the trailer up with the car, and put chassis stands under the end with the ramps, and jacked up the front. So that it wouldn't pick the arse end of the car up. Tried to drive the car on, but the bumper was up against the trailer. There was about a 2 - 2.5" drop from the trailer top to the ramps. I couldn't even take them out to place them on the top. rolled the car off. I had to take the headlights and grill off to take the bumper off. All with no real tools. Just the ones that came in the emergency kit in the old mans car.
Took about 45mins to finally get the bumper off. Drove it up and tried to get it over the lip. It just bucked around and span wheels. rolled it back off. Found some wood that looked like it was a fence at some stage, as it still had partial rails attached, and pretty little decorative tops, and place it between the ramp and the trailer.
Pulled the stands out from underneath, jacked the front of the trailer up more. I left it attached to the tow car, cause otherwise it would roll around, because the trailer hand brake didn't work. The rear of the old man's car was almost off the ground.
Drove the car up the ramps, over the wood and the front end was on. Winched it forwards but it was getting caught on a bracket that the exhaust was mounted from. I wasn't going to roll the car back off again, so I got some wood, and jacked up the car off the trailer. The whole car moved forwards about 1/2 a foot with a bang, as the bracket let go of the now bent trailer top.
Got the car on it, positioned it in the middle. I had a wheel chock under the front, and winched the backend down. Also had the front held down too. As we were driving back, I was braking to turn onto the Hume, and the damn car moved about a foot forward, crushing the wheel chock, hitting the front of the trailer, and pulling the rear into the side, due to the way the rear end was held down. Got out again, tightened all the tie downs and drove the ****er home between 90 - 100km/h. This is in a 110 zone mind you.
Next thing that pissed me off was that now the car was a foot forwards, the cars rear end was squatting. Lights in the air, and the chain that linked between the car and the trailer was running along the ground. Stopped again, fixed the chains got coffee and drove home.
I got home at 12.15. Backed the trailer into the drive so I could drive the Telstar off the trailer. 12.30 rolled around and the car was off and I was inside.
Was defiantly a painful exercise, and if I had the $400+ to get the car home, I sure as hell would have done it that way.
Chris mate! I know you are going to kill me for this! I have RACV membership that covers me in any car. You should have said and I could have got a truck. Only thing I am not 100% on is whether it is tow home or to the nearest repair place especially at that distance. We were going to do that with ChrisNichollis GTS if he needed it after the shunt on the way to PI back in Feb.
Glad you got home eventually though mate.
Oh and Aaron, Dan and I unfortunately now know why you have that username! Just please dont put the photo up! I shall be undertaking a course of hypnotherapy to try and cure me and before anyone trys to guess what that means, the man took a photo of his own bare ass on the street as Dan and I were walking behind :chairshot :chairshot
oh yeah.. I kinda forgot about that.. or repressed it.....
maybe you should try to do the same
:uh-huh:
James - the bloke with the lifetime pass reckons his son used to race Cody and kick his arse, but he decided not to continue racing because it was too dangerous! hahahaha *cough*
Bummer Scott :D
But what would a Wang weekend be without some kind of adventure!
Glad you got it home OK though.
Let us know if you need a working bee weekend to get it all fixed up. I can stand around and call total strangers 'weak' while you guys do the work :D
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
