Shell helix Ultra has a viscosity rating of 5W-40.
The first number indicates the viscosity of the oil at low operating temperatures, and the second indicates the viscosity grade at 100C.
Check this website for more details:
http://www.viperclub.org/articles/oilfaq.html
5W-40 is perfectly fine for Skylines, and I've noticed the Shell oils stay cleaner longer than the Mobil oils in my experience. (Not that Mobil 1 isn't good. That too stays very clean).
But I dont EVER recomend Castrol mineral oils for ANY car! That has a tendancy of getting dirty very quickly! I dont know about their synthetic oils though...
Zahos
Originally posted by INASNT
while we are on the topic, whats the item numbers/brands to use for the oil and fuel filters??
For Oil Filters, I use the Ryco Z145A (yes, the one for 300zx's and VL's).
I've also used a Valvoline one (the equivalent item number is V04 from memory).
Cheers,
David.
Originally posted by McCracken
INASNT (and everyone else), change your fuel filter asap if you haven't already.  This *cheap* little item can easily rob you of performance and economy if dirty!
i have had my car 1 1/2 years and have changed it twice already! :P
  • 2 months later...
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
