GTR parts and HKS Turbo KIT
HKS GT2530 turbos, HKS low mount manifolds, HKS dumppipes, upgrade actuators, comes with oil lines, bolts, front pipes, basically everything that is on the exhaust side comes with this setup including twin turbo pipe. turbos in good condition.
$3300
HKS? pod filter and adapters suit GTR+fittings
$180
HKS step 1 264 cams 3000kms old exellent condition
$800 pair
Sard injectors 660cc suit GTR or GTST top feed, Nismo fuel reg, standard GTR fuel rail modified to fit injectors, grex 275ltrs/per hour intank pump suit up to 350rwkw 3 months old $850 lot
Standard GTR rods
$180
the turbos dont blow any smoke and are still in good condition, i think the turbos have done bout 3000 on my car and 15000 before i bought them of a mate. he was running 1 bar and i was running 1.4 bar
Asking for a mate.
How many k's have the turbo's done?
Any leaks, smoke out exhaust, shaft play, etc.?
How much boost were you using when they were installed?
Sard injectors are they; top feed(GTR) or side feed(33 gts-t)?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
