- 2 door
- Definitly <150,000km, preferably <100,000.
- MUST be a manual (otherwise, what's the point? :uh-huh: )
- don't really want to spend more than $15,000
- power windows and/or sunroof would be a big plus.
- some schmick wheels would be good (always get compliments on my wheels)
- sound system is an advantage
- good exhaust would be good too
- i'd like a turbo timer and boost controller, but i can add them in a bit later if need be
it's late, i'll think of more of what i'd really like tomorrow
https://www.sau.com.au/forums/topic/81675-wtb-r33-gts-t/
  • 1 year later...
- 2 door
Where are you? I have a very nice one for sale in your price range in Melbourne that's just had a full respray.
https://www.sau.com.au/forums/topic/81675-wtb-r33-gts-t/#findComment-2476128
- 2 door
Cjdexter,
Where are you located? I have a 1995 S1.5 R33 GTS-T for sale in Sydney:
Metallic silver in colour, 5 sp manual. Only done genuine 60,000Kms (weekend driven only) and serviced every 5,000Kms with Castrol-R fully synthetic engine oil.
Airbag, power & tinted windows, remote central locking with insurance approved CAT 4 alarm and immobiliser with movement sensors, power windows & mirrors.
Pioneer in-dash CD player with Pioneer voice controlled 12-stack CD player in boot. 1 Pioneer amp and 1 Kicker amp, 12" Kicker sub woofer in boot. (Stereo alone costs $4,000)
Apexi racing air filter, TurboXS blow off valve, 3" mandrel SuperCat exhaust system, Cusco adjustable tension rods, upgraded shock springs, SARD racing boost gauge, Apexi turbo timer with AF meter.
18" Manaray wheels (deep dish):
18x8.5 with 235/40/18 on the front
18x9.5 with 265/35/18 on the rear
(Wheels and tyres cost - $3,000)
I actually after $16,500 but can reduce price to $15,500 without the stereo. I've had the car for 5 years and first owner in AUS.
Give me a call on 0403 211 288 if interested.
https://www.sau.com.au/forums/topic/81675-wtb-r33-gts-t/#findComment-2483876
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
