Can I please have some more pm space? I'm getting up to 10 pms a day now and my box gets full too quick.
Also, Christian, you said I could have a [email protected] email address. Can I please get this happening?
Anyone who can help, should feel free :D.
Thanks be for anyone who can help me. Please please please.
try your user options Adam....I got an extra 100 a while ago (went from 200 to 300), but I'm sure I did it myself in there somewhere  :confused:
I've got 500 now..
Yeah, you have to activate yourself in your user options sometimes.
i did to mine for one of my 100pm upgrades
yea i had 200 or 300 and now i am down to 100 :O can i please get this bumped up to 200 at least i am cleaning it up a bit i guess thats a possitive from this.
the archiveing feature is pretty good to do this. as u can get it to send the PMs to your email in one HTML file.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
