Hey all,
im thinking about putting in splits on my R33 S2
and i was just wondering how to take out my pillars so that i can put in my tweeters?
the place that i am looking at putting them in is the pillar where the square bit is
if anyone knows what im talking about?
or am i wrong and there is nothing behind that ??
or it is impossible?
do i have to take my whole dash out in order to take out the pillars?
thanks ppl!!
https://www.sau.com.au/forums/topic/81701-driver-pillar-removal-for-splits/
will do guys!! thanks for the info
but what is that square looking thing on the pillar?
like i said it looks like that there is a tweeter behind it.
i jumped into my friends car and it is the same car as mine and he didnt have
the square speaker cover?
i was like wtf?
  • 3 weeks later...
i was like wtf?
The square on the A pillar is a factory grill with a factory optioned tweeter underneath it. I had this in my old R33 sedan. There is bugger all room behind it to mount most aftermarket tweeters from component sets. But I would suggest trying your tweeters in different postions to get the optimal sound.
I have been into SQ for quite a few years and would have to disagree about mounting tweeters in the kicks. Well if it does not yeild the best result from your speakers. I have an S2 R33, initially I mounted the tweets in the kicks, along with angled pods in the doors ( hiding under the door trim ), but I found the soundstage fairly low, mid steering wheel height, and I also found the steering whell blocked a lot of the highs coming from the drivers side. Legs also can get in the road to block highs.
I played around with mounting points and came up with them in the bottom of the A pillars firing INTO the windscreen. I was suprised at the lack of speaker seperation as well. I am very happy with how it is sounding now - wider, higher and clearer.
To get the A pillar trim off (4 door may differ slightly):
unscrew passenger strap/handle by using a small flat head to pop the screw cap/cover.Unnscrew with philips driver.
pop B pillar trim out where it meets A pillar trim.the A pillar trim goes underneath so you need some room to allow it to come out.
Pull A pillar trim out at top of windscreen, there are about 3 maybe 4 clips going from here down to the bottom of windscreen.Work your way down the trim pulling as close to clip as possible, they will be pretty tight, but I have never broken a clip or the trim.
Once unpoped swing B pillar end towards the middle of the front seats and lift windscreen end up and out. Be careful not to break any wires though.From memory the factory tweeters are mounted onto the trim panel.
From memory the factory tweeter cover is easily removable. I can't remember how as it has been 4 years since I had my one with these mounts. After taking A pillar trim off it should be fairly easy to see how the grill comes off.
wow that is alot of work...
that install on the pillar looks pretty cool!!!
but i opted for the easy install right behind the rear mirrors
thanks for all the info guys!!!!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
