Hey guys I caught up with an old mate over the weekend who I found out has his own tiniting business called "art of tint".. He has been been tiniting for over 10 yrs now and has 5 employees so he doing pretty well. I saw his car which he tinted himself and the tint was immaculate even after 5 yrs :D. I proposed the idea of a tint group buy to him and he was very interested. He usually runs his business through word of mouth but I convinced him to give sau.com a go.. So here is the deal
Standard Tint, called extreme: Darkest legal tint will cost $140 for a 2 door e.g ute and $175* for sedan/coupe.
The Best film around, called 3M: Darkest legal tint will cost $155 for 2 door and $200* for sedan/coupe. *price for typical import may be higher for other cars.
The prices mentioned are the prices he give to dealers.
Of course other colours are available e.g. mirror, pink. For prices on these ask me and I will get a quote. Most colours cost a little more due to less demand.
Numbers Needed
5+ to get this price.
Warranty
lifetime on any workmanship defects :) .. I doubt you will need to go back.
Who wants a tint
1) rmahnovetsky 3M confirm
2) EUG interested confirm
3) bazr33 interested confirm
4) wallystyles interested confirm
5) hungry6 interested
6)
7) ...
next round
1) LiAm interested next round
2) predator
End Date
I will run this group buy for 2 weeks. If I get more then 5 people within this time I will organise a tint session for them and run another group buy.
https://www.sau.com.au/forums/topic/81752-brisbane-window-tint/
hey sounds pretty good
how long does he need the car for ?
can he get the window tint , that has the top portion of the window mirrored?
if he can in the 3m style, how much would it cost?
Thanks
Barret
Mirror tint is much harder to do so it costs a little more. Full mirror tint or half mirror is approx $300.. let me know if your still interested... There is warranty but no paper work as it is illegal..
LiAm: I'll ask him if he will allow me to give his number out to others. I have no problems letting you all talk to him, I just dont know if he wants 100s of people ringing him up
:P ... I'll get back to you on this..
Well it looks like we have enough people in the GB I'll pm you all an see if you all are still interested..
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
