FS: Defi BF gauge set and cusco oil catchcan
Depends on your hp target/if you want to max your turbo, in my experience a twin scroll housing will spool like a much smaller single scroll housing, with little to no loss of peak hp. If you want quickest spool, Pulsar sells 0.85 t4 ts housing for g30 and g35 at less than half price of Garrett's housing.
Ring & pinions are not interchangeable between long and short nose. Pinion is longer in a long nose diff. Cheers. -
I believe it is a r33 throttle body form any rb25det that will work, so I ordered one of these up, we will see.
if anyone else is wondering, they rotate nicely and with care can rotate them to any orientation without issue. in doing so I was able to eliminate the cross over hose from rocker/valve cover to cover, routing around the back and opening up the space above the coil cover, making the engine look much cleaner.
In Sydney. I didn't want to update the cluster originally for that reason of, I had no idea where to find someone who does calibrate the km's, also it's expensive af lol. Just wanted to make my faceplate look a bit more modern.
