I too would like to know about ELF excellium. I saw it up at the local oil n filter garage and they had Beau Yates' drift australia rexxie there as a promo.
The rep reckoned it's the same level as motul 8100 but $10 cheaper.
To be honost I'm not fussed about saving $10 on an oil change cos it's the stuff keeping my engine alive.
On the other hand if ELF is better or the same as motul and they're likely to stay easily available and a reliable supply I'll make the switch as I'm keen on ELF's racing heritage (although that's probably got no impact on the oil I'm getting but hey it makes me feel fuzzy).
Any thoughts anyone?
just a quick question, might sound stupid but i never found out how much oil you actually have to put into an rb25t? does anyone know how much oil is recommended?
A bottle of oil is 5L - you won't need more than that. To get it right just use the dipstick :D
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1489028
I've found that my rb25 takes about 4.5 L when I change the oil filter too. If I don't change the oil filter, then it takes about 4.2-3 L.
The cheapest price that I can buy motul 8100 for is $52 by buying them in bulk. I have never found ELF at less than $55.
I have used 8100 ever since I got the car, and it has held oil pressure well, does not get black by 5000ks (only medium brown) and is not too expensive considering oil + filter costs around $60 (a garage will charge you about $80 for a change using their shit oil). So I stick with the motul.
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1489137
WTF?!!! your new oil brings on the boost faster??? I would love to see that. BTW are you sure you had motul 300V in there? i only ask as 4 litres of 300v is $100 and in my experience would be the best oil i have used.
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1489291
That's not a good thing, it could be argued holding colour is in fact a bad thing. Oil has a detergent action, as well as lubricating, it cleans the components it touches. So if the oil stays clean, either the engine isn't "dirty" (unlikely) or the oil is lacking in detergent quality.:D
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1489335
yeah i had motul 300v chrono in. its about 89bux at autobarn for 4L. and yeah it seems heaps better wid elf... then again i havnt changed my oil in like 8500kms let alone the oil filter lol.. and yes im pretty sure its boosting faster then usual..
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1490145
Hi Sydneykid
You're quite experienced, so can you please tell me more about oil going black?
This is what i've noticed by doing some tests. If you put engine oil in a beaker, and heat it up really hot, it starts to smoke and burn. After a spirited drive, I also notice that a bitta smoke comes outta the engine on all cars (I've tried this on 4 cars).
I was under the impression that the going black was due to the constant heating/cooling/reheating which changed the chemical composition of the oil rather than the 'detergents' acting to scrub carbon from the engine?
your thoughts please?
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1490161
Hi Sydneykid
I am not a chemical engineer, so please excuse me if I don't get into the science. We regularly send our oil (out of the race cars) to Castrol for analysis, they report back on;
1. The condition of the oil itself, whether it has retained its lubricating qualities or it has broken down and is no longer lubricating. This tells us if we are using the right oil/viscosity for the loadings the engine carries in the races. And whether or not we are running it at the right temperature (ie; the oil cooler is doing its job).
2. The contaminents in the oil, lots of possibilities here. High levels of unburnt hydrocarbons are a sign of too rich fuel mixture or leaking injectors. Burnt hydrocarbons are a sign of leaking valve stem seals (particularly exhaust). Glycol is a sign of a leaking head gasket. Bearing material is a sign of worn bearings. Aluminium is sign of worn/cracked pistons. Cast iron from cracked block etc etc
The bottom line for us is we don't get reports back with issues in #1 that would indicate we are "cooking" the oil. If it is discoloured, it is because of #2, mostly due to the burnt hydrocarbons that get into the oil from the valve stem seals, past the rings etc.
My previous comment was based on the posts to date that indicate no one was using low quality oil that is likely to suffer from excessive loading or temperature. Hence any discolouration was as a result of contaminents, with detergent action arguably being the difference when all other things are equal, ie; the same engine with different (but still high quality) oils.
Hope that clarifies:cheers:
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1491064
Yep, It does. I haven't had my car for very long. The compliance shop put in some castrol semi synth oil, which was probably middle of the range stuff. After about 5000 ks, the oil was the same colour as the motul 8100.
I have not used another top of the range oil in the rb 25.
Perhaps it would be beneficial for sau if people could list:
1. what brand and 'model' of oil they use
2. what colour the oil was after x number of ks.
3. the type of driving done durin the ks
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1491078
Off topic a little.
I've recently moved to Castrol 10w60 over Motul 8100 5w40.
The left over 5w40 (~700ml) I used to throw in an old Jonny Walker bottle.
Shaking it used to easily turn it to froth.
The Castrol 10w60 on the other hand is really hard to get air in to it.
You get the few little bubbles but it doesn't turn to froth like the Motul gear.
It is also noticable thicker.
With regards to the colour of the oil, I find its always dark.
https://www.sau.com.au/forums/topic/81764-engine-oil/#findComment-1491477
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
