  • Replies 98
Posted Images
Unfortunately not.
the deisgn of the fronto of the GTR means that you can't do it with aluminium.
Yuo can however buy a Carbon Firbe moulded uber cool thing for like $500!
ARC make one for the R34 GTR in aluminium. But from seeing how the ARC one fits (or doesnt really fit) on the R33 GTR its maybe worth staying away from. Oh well :)
Good luck with your group buy and thanks anyway.
Okay gents.
In preperation for the end of this group buy, being Friday, could you all please post your postal suburb.
I'll ask for a full name, phone number and address later.
The address that I will ask you for will be your work address, because TNT require the package to be signed for.
So, what are they?
BASS OUT
Okay guys, the time has come.
I've check transport rates and it as approx $20 for most locations for freight.
So....
Please deposit the funds as such
Account Name
Peter N Blythe
Back of Melbourne/Westpac
BSB: 733 382
ACC: 586817
Amount $100
Please put AIR and then your user name into the description of the deposit.
If you deposit the money at a bank, please ensure they also do this.
Then, PM me your business hours address and phone number and real name.
When all is sorted I'll place the order and get the parts made. I don't expect this to take any more than 7-10 days.
I will advise when the parts are ready and ship ASAP
If you are in Melbourne, you can pick it up from a club meeting or wherever.
Cheers
BASS OUT
paid and PM sent. Please advise when you receive payment, and that my instructions are clear. Thanks mate! Andrew
Hey guys.
Looks like everyone has paid, so it's all good.
Parts are already being cut, and I should be able to dispatch them by mid next week.
Cheers
Pete
Just confirmed with the router, and I'll have the blank plates by the end of this week, whould get them bent either friday or Monday.
Guest
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
