Soarer V8 is the sweetest, but that's my opinion.
I just don't think the garage is complete without a V8 of some type. I'm not keen on the latest Holden 8's though. Sound like a vacuum. Be nice to hear what the remus does for Vusters'.
Here you go Geoff. Maybe a loud vacuum? :thumbsup:
http://users.tpg.com.au/mcurro/clips/ls2Re...sRaceSystem.WMV
Sorry. It was taken on my little digital cam. Plus I had to shrink it to a downloadable friendly size.
Higher reving? Here's a dyno run.
http://voodoo.theddrzone.com/carstuff/remu...s2remusdyno.WMV
Very nice :D
  • 3 weeks later...
A couple of things, that wing, that wing does absolutely nothing for me, put the bloody gtr wing on if u want it looking like that ! The twin cannons. hmmm look like, a little bit odd, but i would need to see it in person. Alot of damn work has gone into it. At the end of they day, damn great thing he has done, something different. What he really needs on it tho, is a nice stroker kit, u reckon you could fit a twin turbo set up in there, hmmm hardly looks like it.
But its not in vic, so i cant say. Change the cover colours !!!, hehe.
love to see it on fullboost one of these days :rant:
Oh and nothing sounds better than an old carbifed v8... mmm rumble
Edited by Coupe-This
  • 3 weeks later...
WHAT A WASTE OF TIME ,EFFORT & MONEY- I HAVE A LS1 STATESMAN & A 96 R33 GTS-t SKYLINE & I CAN TELL YOU RIGHT NOW THAT THE SKYLINE WINS HANDS DOWN FOR INSTANT PERFORMANCE & HANDLING & THRILL FACTOR. THE LS1 WOULD HAVE TO BE THE MOST DOUGHY , WEAK V8 I HAVE EVER DRIVEN , & UNTIL YOU WIND IT UP OVER 5000RPM ITS AS WEAK AS P.SS. STICK TO THE BEST 6 CYLINDER DONK EVER MADE IN THE HISTORY OF THE MOTOR VEHICLE I SAY!!!!!!!!!!
to those saying it'll be too heavy, or heavier than a VH45 ...
the car with LS1 & T56 now weighs 10kg less than it did with the RB25DET
ive seen a Z32 300ZX with the same conversion and it dropped 150lbs from the VG30
OHV all alloy V8 = very light
OHV all alloy V8 = better weight distrobution too, as it can be mounted further back in the engine bay (OHV and V configuration means its very compact for its capacity). There are guys on the RX7 forums retaining the 50:50 weight distrobution running LS1s instead of 1.3 rotarys.
What do you expect from a luxobarge? The car weighs 2 tonne. I haven't heard anyone trying to compare a statesman to a skyline.
I've seen the car in the flesh and its a very nice conversion - and my god does it sound good. Plus 429rwhp is a fair amount in anyone's book.
I'm all for thinking outside the square...We have an LS1 about to make its way into a RWD Nissan platform too...
Jash
  • 3 weeks later...
My "lux-0-barge" does 12.5 @ 109mph and would beat a lot of the cars on here. Stock they are doughy as they are supposed to be smooth and comfortable, not a sports car.
Now i have both and about to turbo the f**ker too. 380rwkw anyone?? hehe
  • 1 year later...
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
