They are Pivot Stepping Gauge Series
• Lightweight
• Reduced Vibration
• No Overshoot or Waver
• Noiseless Stepping Motor
• Dashboard Stand Included
• Super Extra-Fine Steps Ensure Extra Smooth Movement
The Pivot Stepping Gauge Series was designed for use in racecars, but can be used without modification in your own car.
Consistent Movement
Pivot's stepping gauge, with it's original computer drive circuitry, stepping motor, and instrumentation design, brings to reality a gauge that offers high response and consistent movement without overshoot or waver.
Reduced Lag Time
Racing gauges have never existed with such consistent movement, and overwhelming high response rate, without overshoot. It gives a true sense of an engine's movement and change. Also, the Super-extra fine steps (Pivot: 0.312°, competitors: 0.9°) move smoothly and our display offers you an easy to read 281°.
Lightweight Construction
The Pivot Stepping Gauge series was constructed lightweight by design. A lighter gauge means less vibration and improved visibility.
Developed to match the needs of Formula 1, circuit, and rally racing, the world's high pressure drivers overwhelmingly choose Pivot due to Pivot's commitment to creating innovative, quality, competitive products
https://www.sau.com.au/forums/topic/81863-new-pivot-gauges/#findComment-1486942
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
