;):D -HKS T51S /T51R spl turbo kit
*exaust manifold
*dump pipe
*HKS external waste gate
*HKS T51S turbo
*HKS T51R
*screamer pipe
$5500.00/HKS T51S
T51R spl $6500
to suit RB26 and the turbo
-KKK27 turbo brand new $1500 or can come as a kit for RB20 for R32 that include kkk turbo,manifold sard exteranal waste gate,dump pipe
-hks blow off vavle super seqental $200
-impuls 280km speedo brand new still in box $200
-mine speedo 320 got over 70000k on it $270
-mine computer to suit 550cc for GTR R32GTR $300
-R32 dash for two gauge after market $80
-HKS t51S turbo new $2500 used $1700
-Sard 700cc injector with hkS or with Tomei rail $1200
-Sard feul reg gold in colour $240
-Z32 AFM with plug $270 each.
call or email
.0415642296,[email protected]
Din.many more parts left
Edited by dinzlr
https://www.sau.com.au/forums/topic/81873-gtr-parts/
  • Replies 68
Interested in some of the gear, PM sent.
-HKS T51S /T51R spl turbo kit *exaust manifold
                              *dump pipe
                              *HKS T51S turbo
                              *scream pipe
                                                     $5500.00/HKS T51R spl $6500
to suit RB26 and the turbo compressor been polish
-split fire coil pack $600
-Z32 air flow meter $250
-nismo 550cc injector $500
-Sard external wastegate 55mm $700
-twin blitz blow off vavle for GTR $250
-GTR twin turbo kit with everthing $1300
-ARC air box for GTR R32 $200
-mine dash 320 got over 70000k on it $300
-mine computer to suit 550cc for GTR R32 $500
-mine dump pipe for GTR *2 $300
-HKS oil cooler for GTR $300
-osgiken cam gear suit RB $300
-Brembo break off R33 front $1200
-TD06 turbo like new $1300
and many more also copy product for cheaper price for more info or any product
you looking for please call or email
https://www.sau.com.au/forums/topic/81873-gtr-parts/#findComment-1487856
