Head gasket u reckon?
I checked the engine oil dipstick and it was still full(after drain) and seemed fine.
I had a look at the transmission dipstick and it was very watery and almost empty, looked similar to the bowny milky liquid that came out of the radiator...
Is there anyway of testing the head gasket?
You could have trany oil in the radiator . Undo the 2 pipes that go in the radiator ( trany oil pipes ) , undo the radiator cap , block one of the pipes and blow compressed air in the other , if you see bubbles on the top then you know its trany oil .
You have to get it fixed very quick or you will destroy your trany , good excuse to convert to manual though .
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
