  • Replies 51
Hmmmmmm Thanks Dave for rocking up....
What happened to everybody? Well because of the lack of people showing up I have had to re-schedule The meet Date too Sunday the 28th of this month Heaps of time to know about it. This will be the latest I will be postponing it too. I hope everybody will be able to attend....
pm me if you are not sure about if you will be there, This is very important! Also I cant leave it any longer as we might miss out on a good spot.
ok Im going to give ppl til the 26th of sept which is a monday "I kow" :D Perth Royal show but this will be the latest time to get a cheap price
The Team name will be "JSHOP" So in case you dont come and meet up you will be able to still enter but be aware it will be $200 from then on to enter and sleep, ATM its $120
As far as I know the list goes
Chris - R32 GTS-T
Ant - R32 GTRrr
Dave - R33 GTS-T
Robin - MR2 (4A-GZE)
Tim - S5 RX7
Kamo - Toyota Chaser & R32 4door GTS-T
Drkside - R32 GTRrr
Ian - Holden PV (Its not a V8 but man you should hear the sound system)
Unscarred711 - R33 GTS-T
Frosty - R32 ?????
Meet point will be Narrows Near the Freeway again. at 4:30pm
Please rock up
For those a little bit worried I dont touch the money becuase you will have to pay by cheque and im going to send it off the next day, Or you send it off tues but.. They say send it off together and you will have a better chance at being together.
7yphon
Pm details so i know whats going on. :O
ok Im going to give ppl til the 26th of sept which is a monday "I kow"  ;) Perth Royal show but this will be the latest time to get a cheap price
Chris - R32 GTS-T
Ant - R32 GTRrr
Dave - R33 GTS-T
Tim - S5 RX7
Drkside - R32 GTRrr
Frosty - R32 ?????
Please rock up
7yphon
Chris - R32 GTS-T
Ant - R32 GTRrr
Dave - R33 GTS-T
Tim - S5 RX7
Drkside - R32 GTRrr
Frosty - R32 ?????
Please rock up
Ok guys I need your imput. I want to know what you guys are thinking anything you would like to have or see at motorvation. Im going to try and org a BBQ or maybe ask the PGA group nicely :P I have some friends there.
c'mon ppl lets get a group together quickley hey.... shit we need some decent quick imports asap.... otherwise ford n holden r gonna make our small display look like crap...
we got someone coming to set up like a shop n stuff... and my car 32 will have a neo 25 in it by then... IF not my chaser will have 2000w RMS of bass crankin so comon
OK Guys Dont forget this Monday its the meeting and I havent forgotten you frosty I have the forms for you, Ill give them to you on the day. Ill make it around 4 in the arvo as ppl might have things to do I understand. I also have stuff to do that day. Reamber this is the final meeting I will hold if nobody rocks up then I will presume that you are not comming, If you are not sure come anyway at least then you will know what events are going on and stuff, Dont give you money to me because they do not want cash so if you can use cred card on the details or at least cheque for those who are lucky enough to have that option.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
