hi all can anybody hep me out i think i have a coil pack problem and i need to know how many if any are bad because secend hand are next to impossable to get here in ireland because skylines are still rare and parts arent readly available so i will have to go to nissan and the are very expensive there about 200 eruo each
so if anybody can help i would really appreciate it :uh-huh:
also was givin a set of kie office coilovers by a mate i know they have a drift team but cant find any info on them if anyone herd of them and has any info would appreciate that aswell
thanks all :thumbsup:
https://www.sau.com.au/forums/topic/81913-how-can-i-test-a-coil-pack/
Coil packs: Remove the cover, and with you car running remove each coil pack plug individually.
If it makes your car run rougher, then that coil pack is ok. Reconnect that plug and move onto the next one.
If you come across one that makes no difference to the way your car is running then that coil pack is stuffed.
I hope that makes sense!
Even easier for the diagnostic is to take out the packs and use short plug leads to connect and disconnect.
There is a cheap alternative being investigated in the Queensland section so take a look in the maintenance day thread or talk to ska
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
    • Sweet, yeah hoping stock gears will hold up. May use the transbrake feature on hill climb starts so that will test it.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
