Hi,
I put a cooler on my car approx 2mths ago and since then I noticed a flat spot from around 3500-5000 rpm. The piping is 2.5" back to both the standard piping
(ie routed behind the cooler). However, on the left end tank of the cooler (looking from front), I've got a 180 Deg Bend that was cut and modded (made it a mitred 180 Deg bend) to allow the bend (as i'm still using standard front bar) so i can route the piping behind the cooler. Would this be a problem for pressure and flow?
Also the size of the cooler is a 800x600x73 (i think 73 anyway). I've also got a 3" turbo back exhaust running 10psi boost.
Another factor is my coil pack were crappy at that very time as well and i have taped and siliconed them..No longer misfires but i have read that main "missfiring thread" and in that thread some people where getting flat spots roughly around that rev range.
As a result, my car is running slower than it was with just a stock cooler and 3"exhaust (9psi)
So is it my cooler size, cooler piping or is it the result of dodgy ignitor coils?
Any help would be great.
Greetings All.
I think you will find that the intercooler is too big...unless you DID mean a 600x300...other wise your cooler would be WAY too big for only 10psi...
Flat spot eh...over fueling issues...? Something to do with fuel or fuel delivery??
Cheers,
--Tonba
Why would the FMIC be too big?
They are essentially just a heat sink between the compressor and combustion chamber, so a larger heat shedding capacity = more reliable/greater power production.
I must say that my R33 running a 600 x 300 x 76 did suffer the std ECU flat spot.
Perhaps I'm missing something?
cheers
Your mods sound the same to mine.
I suspect your ecu is richening the mixture and retarding ignition. Time for aftermarket engine management.
Whack it on the dyno if you want to really see what's happening instead of just guessing though.
PFC plugged in with standard base maps immediately removed the flat spot - it did feel like ignition retard was the issue.
Perhaps a significant reduction in pressure drop (vs. the std R33 cooler + piping, + exhaust) means the engine was ingesting enough air to make the std ECU go into a fail-safe, even though the actual boost pressure was unchanged?
You have removed a restriction, therefore more airflow (boost is irrelevant). The AFM is sensing more airflow and telling the ECU (AFM's are blabber mouths, just can't keep a secret). The ECU knows that much airflow is too much, so it hops onto Rich & Retard mapping to protect the engine. Time for some tuning, DFA, SAFC, PFC or equivalent.:D
I'm suffering a simalar flat spot, after installing an EBC. I'm only running 9PSI but it gets there much quicker than before.
I'm guessing the computer sees AF/RPM. so in the mid-range where the boost is incresced it plays up but then over 4500RPM things are just about back to normal so she takes off again.
Well that's my theory........ :confused:
I'm hoping that playing around with the gain will help, if not i will be searching for a vacuum/pressure leak, and then look to the computer. Besides i don't have any money to buy a computer just yet!
You have removed a restriction, therefore more airflow (boost is irrelevant).  The AFM is sensing more airflow and telling the ECU (AFM's are blabber mouths, just can't keep a secret).  The ECU knows that much airflow is too much, so it hops onto Rich & Retard mapping to protect the engine.  Time for some tuning, DFA, SAFC, PFC or equivalent.:cheers:
I'm happy that my deductions about the std ECU were correct - it really means Nissan engineers defined fairly tight engine performance parameters, enforced by a fairly tamper-proof brain. I've gone down the PFC trail, but what degree of success could be expected with an intercepter (eg. Jaycar kit) that fools the ECU into accessing different parts of the factory maps?
cheers
Hi,
A mate of mine told me to clean the AFM so I cleaned and the car now seems to go alot better. I havent pushed it hard all through the gears (only 1st and 2nd) but the lag as mentioned between 3-5K rpm is now gone. I'll do more testing this weekend and let you all know the result.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
