Not a great idea but these are more for longevity rather than response. The bearings add weight to the rotating parts. A good plain bearing should have no contact as it floats in the viscous oil pulled around the journal. It will not last as long though, but well cared for will give a good life.
Interesting.
So a plain bearing turbo would be more responsive than a ball bearing turbo of the exact same size?
I'm curious to know as I have the opportunity to buy a brand new steel wheel'd plain bearing turbo or get a GCG hiflow. The new plain bearing is significantly cheaper though.
I can't work out something ....
is it:
Turbos which keep spinning
OR
Turbos that keep spinning
I guess it depends on whether your car is a twin turbo or a single turbo
:cheers:
Well the bearing will add extra mass that resists acceleration, either positive or negative. This in in the form of the rollers/balls (depending on construction) and the inner race over the shaft. I have seen needle rollers in a different low speed application that run on the shaft itself.
Plain bearing application is well advanced, and the shaft basically runs on hydrodynamic oil pressure without contacting metal. The bearing metal is there as a soft surface for when the parts touch, which it will eventually from time to time as the bearing ages.
It's a choice of longevity, but plains last years and many miles when well cared for.
Cubes , SB8006A CHRA ? . I dug through all the good and not so good GT30 CHRA no's eg 700177-10,11,12,13,14,15,18 and the best 700382-12 . What does that number you gave show or what listing is it from . I've been trying to remember the name of the turbo dealer in north QLD as his site used to have some early Garrett parts lists .
Cheers A
Sorry that last one (GT30R) should have read CHRA no 700177-7 , for turbo assembly no 700382-12 . There are at least 14 GT30 turbine based cartridges I know of and have the part numbers for 11 0f them . Compressors range from GT35 to GT37 to T04S to GT40 .
Cheers A .
Sorry.. I grabbed that number from Ray Hall. His listings appear to be different to that of Garrett them selves. ?!? :wave:
The real part number for the chra is 700177-0014 according to Ray Hall.
I don't understand to be honest as Garrett don't list a GT30R that runs a 64trim comp wheel?!?
Comp: 64trim GT40 comp wheel 2.41(61.21mm)/3.22(81.78mm).
Turbine: 84trim 2.16(54.86mm)/2.36(59.94mm).
I really need to do a bit of reading to understand the trim etc..
One good argument i've seen regarding response, is that the bearing design doesn't matter much, but the blade design does.
IMO its incorrect to attribute the better response of modern turbos solely to the use of ball bearings, because the blade designs are years apart in terms of development.
Cheers :D thanks for that GTRgeoff. You may have just saved me $1000 :wave:
Cubes the 700177-14 cartridge should have a 56 trim GT40 compressor on it . Most people call them a GT3040R . HKS did a similar thing but with a 50 trim GT40 compressor wheel .
Turbo bearing systems . The annular contact ball bearings have very little contact area with the inner and outer races . The reason they have small oil restrictors is that high speed ball race bearings suffer drag losses if too much oil is present . Clearence on ball race bearings can be much closer than bush bearings in high speed applications meaning less "orbiting" of the shaft . This allows less clearence between the wheels and housings raising the efficiency of the compressor and energy recovery of the turbine - less slip losses .
What happens with floating bushes in turbos is a large contact area between the turbine shaft and the oil cushon . The large contact area initially gives a drag or oil shear effect that slows the acceleration of the rotating assembly from low speeds - lag . The collar and plate thrust bearing also has the large contact area drag problem . If there is a carbon compressor end seal (mechanical face seal) its more drag again .
The reason turbos with very low drag bearing systems contine to revolve when the engines shut down is because the mass of the rotating assembly has little resistance to revolving for a short time . The lubricating oil is hot and thin as well .
Cost aside I can't think of any good reason to use a bush bearing turbo if a ball bearing alternative is available .
Lastly would you believe me if I said Garretts GTBB turbos have a lower part count than the bush bearing ones ? Believe it .
That all makes sense to me so I won't dispute it except one bit.
As far as the BB part count goes, I assume each bearing cartridge is a single part, where if you said moving parts it would be different.
White bearing metal is very expensive to replace also when it wears out
spinning it with your hand would be alot slower than it spins when being pushed by exaust gas. Also doing it once or twice with your fingers wouldnt matter, but doing it everytime you turn your car off, can't be good for it?
yeah thats exactly what i was saying, having exhaust gasses pushing it means there is load behind the turbine wheels, but in this instance the car is off and it keeps spinning because the inertia of the rotating parts is enough to overcome the friction of the bearings. of course the friction will slowly turn the inertia into heat and transfer the energy to the oil and bearings over the period that it keeps spinning after the car is off, once that energy is expended it will stop spinning as its converted all its energy into heat.
now if there was enough energy it can be argued that it will cause damage as there is no longer a proper oil supply, but its not really its a very negligible amount of energy when the engine is off.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
