hey guys well in my stagea im having trouble with the attessa staying on all the time and boiling the fluid, cause of something that is wired up wrong, so i been lookin at the attessa wiring diagrams for r32 gtr (must be very similiar to stagea) and there are 3 wires coming out of the attessa ecu which connect to the stock engine ecu.
well ive got an autronics smc installed and therfore where do i hook these 3 wires up?
the wires are:
engine speed signal
throttle signal +
throttle signal -
so anyone know what people do when hooking up aftermarket ecu's on gtr's?
also the diagnostic light on the attessa ecu comes up with 5 and 7 which are ABS right front actuator solenoid or circuit, and ABS rear wheel actuator solenoid or circuit, dunno if they are fualtly or just not hooked up right, as when it had the stock engine/ecu/gearbox etc the 4wd system worked perfectly
hopefully someone has abit of info :thumbsup:
cheers
Brad
by engine speed signal you mean RPM?
Well the Apexi RSM Manual lists shows the pin location of Road Speed Sensor and RPM, for the Skylines, and the Stagea's.
http://www.apexi-usa.com/pdf/technicalDocu...ntation/199.pdf
  • 2 years later...
I have a SM4 in a 32 gtr. The speed signal goes to your HSI 3 on a SM4 and as for the tps + and - you can hook them up to your original tps signal wires to the computer which is ok if you just want to keep it in 4wd but if you want to put it in 2 wheel drive it will change the tps value in your Autronic as i had the same problem.
I am waiting for a answer back from Autronic but i am pretty sure you have to put a second tps in just for a signal to the attessa as the factory ecu has its own output for the attessa controller.
well ive got the same problem how did this get fixed?
lol maybe i need a little more clear i using a standard r32 gtr ecu for my run in and got my pfc to go in next and i have to rewire everything in.
abd have 3 wires left over... and dont know where they go.
whats SM4? and HSI 3?
thanks
Edited by gzzmos
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
