Hi guys, i have a r33 gts-t. My revs are often very unstable, occasionally i switch my car on and the revs keep on moving all around the place.. between 500and 1000 rpm. When i accelerate, the rev fluctuations stop. Or if i leave the revs fluctuating for a short while, it goes back to normal..
I was wondering if anyone would know what is causing this problem, it becomes quite difficult to drive in low revs the car keeps on jerking.
I have a BOV fitted, could this be the reason?
also, sometimes my car almost stalls as i try to take it out of a parking, the revs drop so low that it almost switches off, when u step on the accelerator the revs climb up and it switches back on.
Lastly, when my car is switched on but not moving, if u turn the steering wheel the revs drop very low and the car almost turns off.
Somebody pls help!! i'm beginning to think i made a wrong purchase...
All help will be appreciated,
thanks
https://www.sau.com.au/forums/topic/81950-pls-help/
You have a BOV that vents to atmosphere?
Or the AAC valve needs cleaning (do a search).
thanks bro,
yes i have a BOV that vents to the atmosphere.
what is the aac valve? where can i find it? i would have no idea about it.
hope this wud work for me...
cheers!
https://www.sau.com.au/forums/topic/81950-pls-help/#findComment-1487330
get rid of the atmo bov, this is causing your problem. the engine expects x amount of air in the system your bov opens to amto and air gets vented to atmosphere but the engine still expects that air in the system so it adds corresponding fuel to that amount of air but the air is gone and mixture is wacko and it stalls. change to stock bov
https://www.sau.com.au/forums/topic/81950-pls-help/#findComment-1488121
Engine is under vacuum at idle, so BOV leaks additional air into the engine, severely leaning the mixture.
https://www.sau.com.au/forums/topic/81950-pls-help/#findComment-1488417
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 馃槀馃槀 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 馃槃
