After i put on a NISMO 1.3bar radiator cap ive replaced the radiator top tank, 3 hoses near the rear of the engine and split two hoses at the front of the engine. oh well..blessing in disguise I guess.
yeah I would say that was helping drag up the water temp a bit too. i guess they both feed off each other to a degree and once they start to go up it's a bad cycle. having done a few track days this year and even a 10 lap race (including comp pitstop etc) i haven't got oil temp over 95 and water temp never over 83. i think the duct and giving the air an escape will help a lot.
Are you running std turbos? I'm running the factory ones at 1 Bar - I think the ball bearing turbos run cooler.
Also, you're right if I get the water temps under control then the oil temps fall off too (and vice versa).
I'm pretty sure the readings are right, as i've got defi gauges for pressure, oil temp and water temp.
However, the readings are temps as they exit the engine - the top hose for the rad, and in the remote oil filter block before the cooler. It would be nice to have a reading after the oil cooler and at the bottom rad hose to see what temps the engine actually sees.
Another thing I was thinking was that the engine is running a bit lean, but then the A/F ratios are good at bang on 12:1
Therefore, my conclusions are:
1. the oil cooler is poorly placed
2. the rad is either partially blocked or can't cope with the heat - going to go for a 43mm one anyway
:D
as i understand, radiator caps have that releif of
pressure for a reason(to keep the pressure to a safe
level in your engine) to save head gaskets and hoses,
they are meant to bleed coolant into the overflow
bottle and then suck it back when the engine cools
down.
othewise the coolant level would be to low when
cold and there would be no reason for an overflow
bottle at all
West,
Have you got a 'real' temperature guage to determine if the car is getting hot or not?
The stock temp guage is a 3 stage. Its either cold in the middle or hot.
For example the temperature range in the middle is from 72degree's right up to 102degree's from memory.
102degree's I would consider to be too hot, especially if it is reaching these temps on the street. On the track sure, lap after lap on a stock cooling system will see these temps but definitely not on the street.
Yes i have PFC handcontroller so i can tell exactly. On Phillip Island, after 4 laps mine only read 87c compare to average normal driving of 80c and i also have an oil cooler too.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
