New Intercoolers - $175 Delivered - Pick Your Size
yes i am :-)
Thanks Matt - Your intercooler was sent via registered post on the 2/8 - I have pm'd you with your reference number. Delivery may be taking a little longer due to the fact your in WA
Regards,
Steve
  • Replies 161
Thankyou to all of you that have purchased our intercoolers. We are now almost out of stock of these universal coolers with yet another container load arriving on the 28th of August.
For anyone wishing to secure an intercooler from our coming shipment , you can still place your order online via our website and you will be informed immediately when new stock arrives. Alternatively if you want to simply register your interest for the next shipment, please email [email protected] and we will add your name to the waiting list.
We will inform everyone here once the new container load reaches our factory
DONT FORGET OUR PRICE IS GUARANTEED FOR THE NEXT 12 MONTHS - WE WILL NOT BE BEATEN FOR PRICE AND SERVICE!
Once again thank you for your support
Steve
Just Jap.com
Hey steve just wondering if you have any of these coolers in stock currently as i can drag my but down there on sat morning as i have to buy oil and sparkies off u guys for my car. Also do u have the pipe kits in for these
We have a huge container load arriving on the 28th but you can pre-order your cooler if you like. Piping kits are still in stock depending on which car you need one for.
Cheers,
Steve
We are receiving loads of pre-orders for intercoolers - Thank you to those of you who have pre-purchased. All orders that have been paid for will be dispatched immediately when our huge container load arrives within the week
We have a HUGE number of intercoolers coming, and we plan to continue this offer for SAU forum members for along time yet.
Thanks
Steve
Does this $175.00 include delivery? I tried to find out on the PayPal thing but it won't let me in for some reason...
If it doesn't work, can I call you up during business hours and give you CC details over the phone? or maybe even just DD it into your account...
How do you deliver within Sydney NSW? Post or Courier?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
