  • Replies 161
whickh one is suitable for an r32 with an rb20det in it?
Hi Roland, the most popular size for an R32 GTS-T is the 600 x 300 x 76mm
Regards,
Steve
hey another question. your piping kits for the r33 gts-t, i have the stock plenum chamber so i just wanted to make sure it was designed the standard position not next to the engine with aftermarket plenum chambers. Also i want to keep a plum back bov on for legal reasons so is the piping suitable for a plum back with an entry point or only atmospheric.
Thanks for your help
The factory cast pipe with the factory bov stays in place with our piping kits. These kits are also designed for use with the factory plenum.
Cheers,
Steve
ow sorry and to add to that atm ive still got the stock exhaust manifold and low mount stock turbo. Will the piping be suitable and when it comes to upgrade will i need to buy new piping to fit a bigger turbo or top mount
You may need to change piping if you fit a large high mount turbo, but if you simply fit a larger turbo in the factory position there shouldnt be any problem
Steve
you just seem to have all the right answers lol. i like that
All pm and email enquiries now replied to
We have another 1000 coming shortly.
Cheers,
Steve
Hi mate, thanks for your enquiry
We have plenty of stock still available
You can place your order online at the URL below:
http://www.justjap.com/forumcoolerspecial.htm
Cheers,
Steve
hey i was just wondering how long they usually take to get to W.A?
Hi Massey, we normally say allow 3-4 business days for delivery to WA.
Cheers,
Steve
Another question. I am interested in the medium size cooler for my R33, however i would like you to confirm that the piping kit would be suited to the smaller cooler.Is there a compatible piping kit for the smaller cooler?
Thanks
Peter
Thanks
Peter
Hi Peter, the 600mm intercooler is the best size for an R33 GTS-T as as such the piping kits are designed for use with the 600 x 300 x 76mm intercoolers.
Regards,
Steve
hey there...i just placed my order for the 600*76*300 cooler to 2774...thanks ;))
Thanks for your order Chris :)
Your order has been confirmed and your payment received. Your cooler will be sent out tommorrow
Cheers,
Steve
Hi Richo, thanks for your order. Your payment has been received and confirmed and your intercooler will be sent out shortly.
Regards,
Steve
I want to fit one of these intercoolers to the front of my 4.2 diesel Nissan Patrol. I think that the bigger IC would suit best but need to make sure that it will fit.
I assume that the dimensions listed are for the core only. Could you please post the overall measurements including the end tanks for the medium and large JustJap coolers?
Thanks in advance!
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
