  • Replies 161
whickh one is suitable for an r32 with an rb20det in it?
Hi Roland, the most popular size for an R32 GTS-T is the 600 x 300 x 76mm
Regards,
Steve
hey another question. your piping kits for the r33 gts-t, i have the stock plenum chamber so i just wanted to make sure it was designed the standard position not next to the engine with aftermarket plenum chambers. Also i want to keep a plum back bov on for legal reasons so is the piping suitable for a plum back with an entry point or only atmospheric.
Thanks for your help
The factory cast pipe with the factory bov stays in place with our piping kits. These kits are also designed for use with the factory plenum.
Cheers,
Steve
ow sorry and to add to that atm ive still got the stock exhaust manifold and low mount stock turbo. Will the piping be suitable and when it comes to upgrade will i need to buy new piping to fit a bigger turbo or top mount
You may need to change piping if you fit a large high mount turbo, but if you simply fit a larger turbo in the factory position there shouldnt be any problem
Steve
you just seem to have all the right answers lol. i like that
All pm and email enquiries now replied to
We have another 1000 coming shortly.
Cheers,
Steve
Hi mate, thanks for your enquiry
We have plenty of stock still available
You can place your order online at the URL below:
http://www.justjap.com/forumcoolerspecial.htm
Cheers,
Steve
hey i was just wondering how long they usually take to get to W.A?
Hi Massey, we normally say allow 3-4 business days for delivery to WA.
Cheers,
Steve
Another question. I am interested in the medium size cooler for my R33, however i would like you to confirm that the piping kit would be suited to the smaller cooler.Is there a compatible piping kit for the smaller cooler?
Thanks
Peter
Thanks
Peter
Hi Peter, the 600mm intercooler is the best size for an R33 GTS-T as as such the piping kits are designed for use with the 600 x 300 x 76mm intercoolers.
Regards,
Steve
hey there...i just placed my order for the 600*76*300 cooler to 2774...thanks ;))
Thanks for your order Chris :)
Your order has been confirmed and your payment received. Your cooler will be sent out tommorrow
Cheers,
Steve
Hi Richo, thanks for your order. Your payment has been received and confirmed and your intercooler will be sent out shortly.
Regards,
Steve
I want to fit one of these intercoolers to the front of my 4.2 diesel Nissan Patrol. I think that the bigger IC would suit best but need to make sure that it will fit.
I assume that the dimensions listed are for the core only. Could you please post the overall measurements including the end tanks for the medium and large JustJap coolers?
Thanks in advance!
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
