  • Replies 116
Do you have any second hand mild steel dual muffler cat back systems for an R33 GTST? or would you be interested in a trade in on a new system? I have an Apexi N1 with silencer in VG condition..
Cheers
Hi mate,
Can you please quote a price for a Kakimoto.R catback to suit a Series 2 R33 GTS25-t Skyline, I'm looking to buy one within the near future.
Thank you.
Edited by RaseR
RaseR, dezz - Kakimoto.R stainless catback (new) ERC33 - $1,149.00 landed in MEL
Do you have any stats on this exhaust? estimated power increase etc? how much for mild steel?
Cheers,
Mark
Cheers,
Mark
Sorry no info. on power increase for Kakimoto.
More info here:
http://www.kakimotoracing.co.jp/image_NS309.html
This model only comes in full stainless steel
Hi there,
I'm looking for a dual tip Exhaust for my R33 GTS-T S2 coupe & have heard good things about both Kakimoto & Fujitsubo. I know that they both sell a dual tip system, but trying to get a picture or 1 is nearly impossible.
I'm also after a system that's a bit louder (not too much louder) than standard, preferable with more top end noise & is not an angled fit.
If you could give a quote on any dual tip (or even full dual pipe) system you sell for my car that roughly fits my description (& maybe a photo or 2) it would be greatly appreciated.
Cheers
Hi,
Kakimoto Hyper 2000 Full mega N1+Dual
http://www.kakimotoracing.co.jp/01-02-02_N...-02_N1+D00.html
Unfortunately it has been discontinued...
I can't find Fujitsubo as well
http://www.fujitsubo.co.jp/mc-prod/
Hi there,
Cheers
I haven't actually seen a fujitsubo twin system myself, but I do know they exist. It's called a Legalis R TDX, trying to search through their site is rather difficult since it is mainly in Japanese, but I've got a feeling not everying they sell is on there either.
can i get a price check on a Kakimoto Hyper 2000 FullMega N1+ Single for an r32 GTR shipped to the USA
- AUD$1,099.00 pick up in MEL
Shipping to USA, have to check but it won't be cheap
  • 3 weeks later...
hey mate do you have a pic of a apexi n1 evolution on an r32 gtst, sorry for all the questions just want to make sure im buying the right thing. cheers mate
Sorry we don't have a pic on R32,
but N1 Evolution has an angled canon for all models
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
