Hi BT, looking for a catback for a SII R33 GTS-T Sedan. would like an oval muffler, not cannon, twin tips if poss.
New or used..
Can collect from Melbourne
  • Replies 116
Hi BT,
im also looking for a catback with oval(twin tip) muffler but for a R34 GT-T. Preferably with just the rear muffler, no mid muffler or resonator & with the least amount of bends, i'd like a system with the least amount of flow restriction. Any suggestions?
Please pm me. Cheers.
New or used..
New or used..
**Note: from last 1st July FUJITSUBO has increased the prices
Hows Fujitsubo Legalis R?
New price - $1,145.00 landed new
Hi BT,
Most Japanese brands do not sell the Muffler alone but available in US market.
For japanese brand, TRUST PE Ti-R catback has straight pipe without centre muffler.
This type of catback has less restriction
how much can u get for a Kakimoto GT1.OZ Racing exhaust system for a BNR32 GTR
product code is N11308 on kakimoto's web site
plz PM me the price and how long does it take u to land it here thank you
PS plz be aware that it's a 90mm pipe size which is different from GTST (80mm)
Roughly $1,150.00 landed (90mm) if they haven't recently increased the price
Edited by BT-Revolution
How loud are the blitz nur specs......and whats the legal amount?
can u list the ones that are legal for the r34 GTT
Legal limit in VIC is 90dB
Only Apexi and Fujitsubo provides the noise level.
Apexi> all of models are over 90dB
Fujitsubo> Legalis R type EVO is under 90dB
Any chance of getting a price on a set of front pipes for a 1989 32 gtr?
Apexi GT-SPEC front pipe for BNR32, 33, 34
Twin Pipe> become 1
70mm x 2> 80mm
Price: $655.00 landed (sea)
Is the HKS Silent Hi-Power: (Full stainless) for an R34 GTT going to come in at under 95db?
How much for that system shipped to Brisbane?
  • 3 weeks later...
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
