It is a common belief that most, if not all, odometers are wound back either here or over there.
I believe it was done to mine.
Thing is, I also believe that the engines are tough and the drive train can take it.
Just check the condition of everything and try not to judge by odometer alone.
Mate, if the 45 thou is genuine you have no need to worry (even if it had a coupla hundred thousand in front of it.
Go by the condition and service it regularly.
El Bee
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1488050
My old RB20DET did 170,000km's, 100,000km's of that was running 1bar and ~164rwkw.
I occasionally threw it on the dyno to check afr's and ignition timing to ensure they fuel pump wasn't going bad etc..
Keep them running well and you won't have any problems for hundreds of thousands of kays.
The motor still had good 145psi in all 6 cylinders when I pulled it out.
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1488062
my 32 gt-r is showing 138ks, which i believe is genuine as the car has been here since 96..
compression tested it on the weekend, its showing 170psi in all cylinders, and i know the car has had an avcr and aftermarket turbos for a few kays..
makes me wonder how many have had some form of tampering going on.. theres no reason a stockie engine (maybe not turbos) couldnt do 200k i reckon.
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1488402
I should also state that 145psi across all 6 cylinders in the rb20det was exactly the same as it was when I bought the car on 67,000km's.
Compression is affected by cam, cam timing etc.. Overlap bleeds off compression, as a result show a lower compression.
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1488524
I have a problem with my Odometer, I bought it a year ago and it was 115000Kms on the Odometer. One day i was driving and suddenly I noticed it says 230000Kms which I believe it's supposed to be 130000Kms cuz I'd only driven it for 15000kms. The old owner told me there is a minor problem with the Odometer it's not functioning correctly sometimes...is there a way to fix it?
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1490710
i'm guessing its a digital odo.
i've heard many many cases of this with digital odo's all of a sudden they jump like 100-200K kms!!!
this is the result of the odo catching up on its true reading after being electronically wound back.
some sydney siders may remember a dealership name B** B*** Toys, rhymes with Fig Joys Toys, on parramatta rd broadway.
heard of lots of cases from them...
i'd suggest making sure your car has all the things replaced/repaired that should normally be done for a car with your 'new' odo reading,
the rest is up to you!
everyone should be aware that realistically, every single jap import has had the clock wound back.
i've just bought a r32 gtr with 80k on the clock, its a 15yr old car, theres no way thats legit!
just do the maths
20k kms/yr
15yrs
300,000kms
and that myth that japs dont/cant drive very much is crap, japs drive as much as we do!
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1492255
SPOT ON!!!
I can't believe the dreamers with the amazingly low K's.
But all this "winding back the clock" stuff went out with white-wall tyres.
They just buy another speedo from the wreckers and use that one. Cheap as.
Come selling time, they re-fit the original speedo and hey, look at the low K's on my car.
Log book history is much harder to falsify.
https://www.sau.com.au/forums/topic/82036-high-milage/#findComment-1492308
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
