Hi Guys!!!
Just got a Clarion VRX746VD in for a customer who doesnt want to buy it anymore which kinda sux coz i went to alot of trouble to order this in and its something that we dont usually do. but these things happen and they have to be dealt with.
Anyhow....
back to the unit
In an environment where ease-of-use is of utmost importance, Clarion refuses to sacrifice safety in its ongoing pursuit for the cutting edge.Thats why Clarion has adopted several measures to increase driver attention, such as equipping its VRX746VD with a function display screen that offers a comprehensive, full-screen portal to all entertainment sources.Clarion goes a step further by employing an onscreen operation tree and menu layout, pro-viding you with a single, easy-to-use interface that enables intuitive access to all audio and visual content, including DVD, CD and TV tuner.
• Fully Motorised 7-inch Thin Type Wide Screen Colour LCD
• Touch Panel Control with soil resistant finish
• Full-Size Front Panel Secondary Display with Flip-Down Control Panel
• Single DIN Size, No Hide-Away Black Box
• Single Play DVD Mechanism plays: DVD Video, CD Audio, VCD
• New DSP Tuner for Improved Reception, 18FM/6AM Presets
• CeNET Control of: optional Dolby Digital/dts 5.1ch Processor, TV Tuner, DVD Changer and 6-Disc CD changer
• Multi-Changer Control, CD Text, CD Titling (Audio Changer Only), Station Titling
• Front and Rear Monitor Lock
• Plays CD-R & CD-RW
• Plays MP3 Encoded CDs
• 3-Band Parametric EQ
• 1 RCA A/V Input
• 1 Video Output (RCA)
• 6ch RCA Line Level Output
• 24-Bit D/A Converter
• Fibre Optical Output for Use with DVH940 5.1ch Dolby Digital/dts Processor
• Excellent off-axis viewing
• 336,960-pixel display
• Screen Resolution of 1440 x 234
• 212W (53W x 4)
• IR Remote Control
• Fully Detachable Control Panel
• Built-In Amplifier Bypass Circuit
Superior Functionality with Honeycomb Keypad-Equipped Touch Panel Control
Operation is simple - just touch lightly on the monitor's touch panel menu screens or use the provided IR remote control. And now touch panel convenience has evolved even further, with the Honeycomb Keypad. The 10- key pad uses a honeycomb design to maximize surface area, making numerical input easier for rapid-access
band and title selection. It also makes operation safer.
Extra-Large Front Panel Display
Close the main LCD screen to automatically activate the VRX746VD’s separate display panel, which provides you with all informa-tion relative to the entertainment source in use. This separate panel utilises a simple, yet accurate display format, providing you with information such as a CD’s “Play Time,” or station information when using the AM/FM tuner.
Ultra-Thin Fully Motorised In-Dash 7-inch Monitor
Armed with the largest display monitor available for in-dash appli-cations, Clarion is coming to market with a 7-inch, widescreen monitor. Fully automated, the monitor can motorise up or down with the push of a single button. For optimal viewing, the monitor is also equipped with five adjustable angles. And if the monitor blocks your vehicle’s air conditioner con-trols,
Clarion provides added func-tionality with its Air Conditioner Access Mode. This feature will tilt your monitor down momentarily, allowing for easy access to your vehicle’s air conditioner controls.
This function lets the audio signal bypass the built-in amplifier so it can be output to an external amplifier in its purest state, without any noise or distortion being introduced by the internal circuitry. Essential if you plan to expand your system with external power amplifiers.
Touchpad Buttons with Touch Panel Control
With its touch-screen capabilities, Clarion’s in-dash 7-inch monitor allows for simple, yet accurate control of all functions, including all visual and sound-related entertainment
The flip-down front panel hides the DVD load-ing slot, and acts as the main display when the 7-inch monitor is closed. When the monitor is open, the front panel display shows secondary operation information along with the main LCD screen.
The box is currently a virgin :D - untouched and still in original wrapping.. still has the tape over the seal :)
I have seen this unit sell for over $3000 and as low as $2200.
I am asking for $1800
To post this interstate it would cost around $30-50. ($20 for insurance)
Once again, there is only ONE available and first in best dressed.
As usual this multimedia unit comes with the full warranty offered by clarion.
**Note**
Before i get spammed with email/pm/reply "can you get other units?" the answer is not at this stage but i am working on a deal with a clarion distributer
Cheers,
Jase
PS- This all-in-1 unit is available to be picked up as of now and can be posted as soon as monday
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
