I thought it was worthwhile consolidating all the Stagea brake stuff in one place.
Series 1
Front Pads - Bendix Premium 1398BP
The generic Bendix code is 1398, the last 2 digits are the pad type (BP = Bendix Premium).
There is an alternative being 1250, this pad is 14 mm thick and the 1398 is 15 mm thick. It seems 1398's are hard to get at times, so 1250 is a good alternative. I found a set of Lucas Premium pads in the 1250 part number. They are the TRW manufactured, European spec material, so they should be OK.
Front Disc Rotors - DBA 4909
These are the same as the S14 200SX
DBA have these in stock currently
Rear Pads - Bendix Advance 1144 or Ferodo XL 1144XL
As for the front, the generic Bendix code is 1144 the last 2 are the pad type.
Rear Disc Rotors - I am going to try DBA 4908 (R32GTR), modified by maching down the OD by 30mm, all of the other dimensions are the same. This is a rather drastic reduction, I will have to check them for cracking for a few weeks before I sign off on their suitability.
DBA has these rotors in stock currently.
Series 2
Front pads - Hitachi HP63H FF
The guys with S2's haven't found a Bendix equivalent yet, but I am sure they will post it up as soon as they do.
**edit by mods** this information is not correct as the offset is wrong for S2 stagea
Front Disc Rotors - DBA 4963 (R33 GTST) modified by machining down the OD by 6mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
**/edit**
Rear Pads - The generic Bendix code is 1399
Rear Disc Rotors - DBA 4908 (R32GTR), modified by maching down the OD by 5mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
I will post up some pictures of the front rotors and the pad install as I proceed through it this weekend.
Edited by Duncan
  • Like 1
https://www.sau.com.au/forums/topic/82083-stagea-brakes/
SK are the DBA4909SL front rotor a definate swap for our stagea s1 as i can get the rotors for about $195.00 each (not retail price) from repco so I need to know as I will order them if they are a direct swap with no modification needed.
Cheers ICE
That's what I have for ours, but I haven't fitted them yet. I am waiting on pads, they should be here Monday. I will post it up and confirm that they fit only when I have actually fitted them.
PS; be careful DBA4909SL is left and DBA4909SR is right.
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1491871
If anyone cares, DBA4909 are also be used on R32 GTSt. So it then follows that S1 stagea front discs are the same as R32 gtst discs. That might help if you are looking for cheap secondhand replacement discs.
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1494775
Good news, DBA have made a batch of 4908, rear rotors. I will be picking them up tomorrow. I will machine them up next week and fit them the weekend after. Then post up some pictures.
PS; I have updated the first page with the latest details as I go.
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1498578
When upgrading the rotors can you use the original calipers? If wanting to upgrade to new calipers any info?
SK did you by the DBA 4909 slotted or cross drilled from the 4000 series? Any pics installed?
Sorry just seen the photo of part number, SL SR so you got the slotted ones.
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1505992
1. When upgrading the rotors can you use the original calipers?
2. If wanting to  pgrade to new calipers any info?
3. SK did you by the DBA 4909  slotted or cross drilled from the 4000 series?
4.  Any pics installed?
Response to your questions follow;
1. Yes
2. Any R32/33/34 GTR callipers would fit, even Brembos
3. I never use cross drilled rotors, they always crack. (Yes, even Porsche ones)
4. No problem, once I have time to install them. Slight delay, no pads as yet.
:) cheers ;)
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1506981
Top work SK, I have sourced some R32 GTR discs and R33 Gtst calipers for the front of mine, will take snaps once done.
:blink: HELP :) HELP ;) HELP ;) HELP ;)
I have tried everything I can think of to upload the brake pad and rear rotor pictures for this thread.
I can see my gallery
I can see the "upload" button when I am not logged in
But I can't upload because I am not logged in.
When I am logged in, I can't see the upload buttom
If I am doing something wrong please tell me. Or if I don't have permission to upload pictures anymore, then please tell me. If my gallery is full, then please tell me. This is very frustrating, and wastes a lot of time, time that I don't have to spare.
:) cheers :)
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1517433
Well SK I have gone from the info you have given and it is spot on for the fronts I have just fitted the 4909SL/SR and the 1398AD Bendex pads to my S1 Stagea. It took me about 45 minutes. One tip is that you need a bolt to help remove the disc from the hub and as I didn't have one lying around that fit I used a bolt front the front seat mounting which fitted perfectly. I will bed the brakes in before check for brake fade. Haven't thought about the rears as yet.
Cheers ICE
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1518834
  • 3 weeks later...
The DBA 4000 series rotors come with temperature sensitive paint on the rotor edge. This is the DBA instruction sheet for what the temperature sensitive paint is going to tell you.
There are 3 colours (green, orange & red) and they change colour (white, yellow & white) at different temperatures. So I will be able to tell how hot the rotors have been. This will tell me what pads and what brake fluid to use.
I will post up some pictures of the temperature paint on the rotors after 2 weeks use and work through what it means to my future choices of pads and brake fluid.
:D cheers :)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1551707
Sk, can you put the Rear Disc Rotors DBA 4908 on the S1 Stagea without modifying it? As you mentioned modifying yours for some reason? I would prefer bolt on with no mods to it.
The 4908 rotor is too big in diameter, now that the gallery is working I will put up some pictures. There is no Stagea rear rotor available from DBA, in fact I can only find OEM Nissan rotors. So I have chosen a DBA 4000 series rotor that is exactly right in all but one dimension, OD. What I am going to do (when I am not flat out with race meetings, Philip Island this wekend), is to machine down the rotors to the same diameter as the Stagea rotors (10 minutes in the lathe).
Then I will test them for a few weeks, give them some stick, tow the race car around etc. If this harsh testing shows up no issues, I will report back to DBA. They may then choose to do the same within their production process, if so you will be able to buy Stagea rear rotors of the shelf from any DBA outlet.
If DBA choose not to do it (due to low demand) then I will organise a Group Buy and do it that way.
:D cheers :O
PS we do this sort of stuff with race car rotors all the time. In fact Tilton, Brembo and AP rotors come in size steps, and they expect you to machine them down to fit your application.
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1559985
Wow! :D:O
Thats some v.intresting information you've posted up SK.
Glad to hear that you're fully experienced with modifying the size of brake rotors.... Im actually mod'ing the Galfer Wave disc rotors on my Fireblade tonight (cant wait! - whoo hoo, I'll have some decent brakes again!), not a huge deal but still a custom job.
Cheers to you,
Brendan
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1560007
  • 3 weeks later...
I have just been pricing some rotors and pads to buy. Where is the cheapest place to get them, also the Bendix Premium 1398BP seem to be no longer available at most places?
I can get the pads for $121 and rotors range from $252 to $315 each for the same ones, DBA 4909 SR ans SL.
Can I get them cheaper?
https://www.sau.com.au/forums/topic/82083-stagea-brakes/#findComment-1593398
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
