I got new pads no problems a few months back, Marc2 helped me figure out what pads i needed and got them sent to his workshop. i wouldn't think they would stop making them as they were on other common cars too. This was for a series 1 by the way
ok...quick questions as little confused after readin this thread.
1. What calipers do Stagea's come with?? (s1) Are they 4 pots?
2. Upgrade calipers ..... is 33GTST worth it, or spend extra and get 33 GTR calipers?
3. I know u guys have mention DBA a stack, anyone here used RDA discs at all??
front calipers are two spot and 1 spot rears, if i was you id go r33 gts-t calipers on the front with dba rotors to suit (slotted) and just get decent pads for the rears and some braided lines all round if ya like :P
r33 gts-t brakes might need 17" rims? or only 16s im not sure, check before u buy :(
front calipers are two spot and 1 spot rears, if i was you id go r33 gts-t calipers on the front with dba rotors to suit (slotted) and just get decent pads for the rears and some braided lines all round if ya like :(
r33 gts-t brakes might need 17" rims? or only 16s im not sure, check before u buy :)
Thats was l was sorta leaning towards. The 4 pot GTST calipers are like $200 (through a mate) .... and l'm sure a set of slotted disc's wouldn't be that much. Are the lines the same for the stagea as they are for the R33, as there would be braided line kits out there already l'd imagine?
Rims are fine, l've got 18's so clearance won't be a problem!! ;):P
Rims are fine, l've got 18's so clearance won't be a problem!! :(:P
im 99% sure the lines r different as the stagea calipers use a banjo bolt line into the caliper and skyline calipers r a metal str8 screw in line.
So really, the best thing for any stagea owner to make it easy for us
Upgrade the calipers to something a little more common
Same applies for the discs...
thats basically the reason l was thinking of upgrading (well and the extra stopping power), esp as the costs to do so werent that extravegent compared to other mods.
Edited by [ STAGEN ]
Yeah i almost bought a set of R33 GTR Brembo's for $2500, full discs and calliper kit, basically bolts onto the stagea. i didn't end up getting it because i decided to get an Autech next year.
my brakes work for now and i don't go thrashing it or carrying bags of cement, so i can stop it without problems. i've had to use the abs a few times already due to idiot drivers.
I have a question..........if the current brakes have enough stopping power to activate the ABS, why do you think changing to R33GTR Brembos will make the Stagea stop any faster?
:) cheers :D
:) cheers :D
Good question - unless they aren't grabbing fast enough (they should be) and they aren't fading (ie you aren't using them a lot ie out at the track etc) wouldn't you be better spending the money on suspension and tires - both of which will improve braking?
Or have I missed something obvious? :P
Yes... very possible. I just went a week with no ABS and no 4WD... just blow an ABS 30amp fuse in the engine bay!!!
:D
If ppl can make a switch to turn on/off the 4WD then the ABS would be exactly the same, but I dont see why you'd want to take off a safety feature as such.
Brendan
:D cheers :(
That's exactly what i took into account when i was looking at buying them. i wanted bigger brakes for the off chance i wanted to test it on track. i quickly discarded that idea because the stagea is anything but a race car.
Or have I missed something obvious? :)
This is exactly where i did spend my money, i spent about $4k on full suspension and tyre upgrade and now the car handles like a dream. i can stick to almost any corner and with the awd i don't lose control where my previous car (r33 gtst) would have. i think i went the more sensible route.
Great tips, thanks fellas.
When Im ready, I'll be grabbing slotted front rotors, good pads all round, and maybe braided lines to the front rotors. That should up the ante somewhat........
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
