I just redid the entire brake system on the Stagea
DBA slotted fronts as per this thread
Bendix 1250 front pads
Bendix 1144 rear pads
Genuine Nissan rear brake discs
Genuine Nissan rear handbrake shoes
Rebuilt all the brake calipers (new seals, new pistons in 1, cleaned, some silver coating, greased)
The total was about $1250
so the dba slotted rotors I got off you a year ago fit, hey Alex?
arranging my tuner to fit the rotors, front pads and allround Maltech braided brake lines, mid next month
Got some genuine Nissan Pit Work Stagea Series II 4WD front brake pads from Japan the other day and this is written on the box:
Part Number: AY040-NS129
Fuga [Y50]: VQ25DE, VQ35DE - '04/10-
Skyline [V35]: 350GT - '04/11-
Also stamped into the pad itself: HITACHI HP63H FF
I have a sneaking suspicion rwd & 4wd are different but I could be wrong
I hope this helps anyone still looking for their SII
If you need more info (pics/measurements etc) just ask!
I find the stock Stagea brakes are good if you have a good pad in there...and trust me I drive it as if its a sports car so braking is very important to me.
not me
even with endless pads and stainless lines with better brake fluid
i was still getting brake fade and other random problems
once i switched to drilled rotors/gtr brakes/and changed the fluid again to some trust fluid
it was golded on the touge
anybody familiar with the 260rs brakes (discs and pads?) i would imagine they are the same as the 33GTR? Wats the 33gtr specs? Like wats the part numbers for the rotors (DBAs) and the part numbers for the pads (bendix, ferrodo ETC). Thanks
Edited by stasis
  • 3 weeks later...
Hi guys,
I hope I'm not asking a question which has been asked before - I have searched. Just like to confirm I have this correct...
Series 2
Front Disc Rotors - DBA 4963 (R33 GTST) modified by machining down the OD by 6mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
DBA have these in stock currently
Rear Disc Rotors - DBA 4908 (R32GTR), modified by maching down the OD by 5mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
Does this mean that a 33 GTST rotor will fit the front of a series 2 stagea, *with* machining down of 6mm? Or without machining? And same with 32 GTR to fit rear of series 2 - it needs the 5mm reduction of OD?
Not talking about the DBA rotors, but stock 33 GTST and 32 GTR parts.
Thanks!
daveb
hi all,
bought some front pads for my series1 stagea using the 1398bendex number
said dont make these anymore but got me lucas pads instead
thought the part number might help people
no. lucas pads gdb3273
also says on box that these are used for
nissan infiniti(usa) o1.98>01.94
nissan leopard 01.93>
nissan maxima qx 10.94>
hope this info can help other stagea owners
Hi guys,
Thanks!
daveb
i have r32 GTR front and rear brakes on my stagea, no problems
My setup, using Castrol Dot4 super response fluid
Rear:
Stock discs
Bendix Heavy-Duty brake pads
Maltech stainless steel brake lines
Front:
DBA slotted rotors
Bendix Advance brake pads
Works very very well in the urban environment. Impressed actually, considering it hasnt been a huge upgrade. Peddle feel is nice and progressive compared to braking performance. Gives me confidence to stop in a hurry if need be. never had an accident before......
Hope that this has not already been covered.... Understand that there are few R33/R34 brake upgrade options but only really need a basic set-up.
Getting some pulsating when brakes are pressed. Local mechanic tells me that my discs are warped but are too thin to be machined. He has offered to order some original Nissan Stagea replacement rotors ex-Japan but I would rather get something done locally to save time and $$$!
Need help from a brake place in Sydney that knows some stuff about our Stagea's & can fabricate / replace brake pads + rotors.
Thanks guys.
Edited by stag
Thanks guys.
You might want t to check the GB section. Theres an ongoing GB for RDA (ithink) brake rotors. Very cheap. You might want to give him the dimension (diameter of your rotors and thickenss) and he will sought you out. Get the slotted ones don get the dimpled onr cross drilled ones as they might crack under heavy use. Let us know if you have any problems
Yudy
Stasis,
i just sent rs73 a pm re: rotors for my S2 Stagea. I did a quick 'stagea' word search in the thread but could only find ure post re: "for A Nissan Stagea it has the R33Gtr Brembo brakes on it. How much for a front and rear? Std, slotted and dimples?...." but no answer.
Did you end up getting them? If so how do they compare to the standard rotors, did you install them your self or how much did you have to pay to get them installed.
Also, what brake pads are you using.... Will be sure to get the slotted ones :worship:
Duncan,
Will give Grey Imports a call tomorrow... are they the ones in Annandale???
Maybe Nathan can help me install the rotors i get from the group buy mentioned above!
Thanks for the contact!
Edited by stag
Stasis,
Did you end up getting them? If so how do they compare to the standard rotors, did you install them your self or how much they you have to pay to get them installed.
Duncan,
Maybe Nathan can help me install the rotors i get from the group buy above!
From memory the sloted front is A$300/paor delivered which is preety good price. I havent got them yet. My rotors will be in for another set of brake pads before i need to change them. I will be getting this rotors for sure when i need them. Im using endless SSS now it came with the car when i imported it in. As it is estimated at 30% left on the pads, i will be switching to EBC Green. Reason is my rears have EBC Green ATM. I prefered Ferrodo though. Cos they say its better to use the same brand pads for front and rears as their coefficients are the same but somo people might think it doesnt matter. I prefer Ferrodo they are only AS$50 buck difference in price between EBC and ferrodo. Its up to you really. Boys on the budget?! EBC, not so on the budget?! Bendix or Lucas, spoil yourself?! Ferrodo. It also depends how you are going to use the car. Normal driving or track? If normal driving EBC or bendix should be ok. Hope this helps.
Yudy
Yudi,
rs73 tells me that he may be able to source some rotors specifically for my S2 RS4's but wanted to check over all dimensions before he can confirm. Have let him know that i will be taking her to Grey imports next week to see what my other options are. On a budget so will probably go for EBC or Bendix, dont plan to take her to the track at this stage :)
Duncan,
Spoke to Nathan earlier today and have booked her in for next week. He mentioned that he has recently done yours & may have some rotors in stock that will fit mine. He sure sounds like he knows what he's on about. Will let you know how it goes. Thanks again for the hook-up!
Edited by stag
Yudi,
rs73 tells me that he may be able to source some rotors specifically for my S2 RS4's but wanted to check over all dimensions before he can confirm. Have let him know that i will be taking her to Grey imports next week to see what my other options are. On a budget so will probably go for EBC or Bendix, dont plan to take her to the track at this stage ;)
Duncan,
You taking your car to grey imports for? For the brake rotors or the pads? If for the rotors i dont think you will find any cheaper RDA rotors around for that price.
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
    • I reached 10 posts and wanted to make my build thread too but still can't add pictures to posts so I have no idea how it works 😂
