Im putting these 4-pots on the front
using Wilwood Superlite bp-10 pads
going to make these billet aluminium 4 piston calipers fit !!! (bolts/lines/clearances)
dont care how I do it they are going on....
ooh yeah.
:P
Pretty flash mate
You will need to design and get milled a set of adaptors out of alloy or something to get them to bolt on
I would also look at bigger diameter rotors while you are at it
Maybe some bigger brembo GTR rotors. I think they are 328mm or similar?
Will they fit under your 17" r34 GTT wheels?
Pretty flash mate
Great work Tangles 324mm will fit under 17in,NO hope with 328mm,
lol not sure what you are on today chuckie?!? 324x32 is brembo gtr size and a good cheap choice for common disc size. tangles you'll need custom brackets to suit but from steel not ally. it may end up expensive because the adapters can be $$ couple of hundred each.
330ish is fin under 17s, 355 can fit but requires the right wheels and will be very tight. so 324 brembo size is a good choice.
Was & earlly SMOKE&JOKE :) ,Good JOB it wasn`t CRACK PIPE :):wacko:
Will have a look at 324mm with some DOGBONE`S on stag at some time ,may be when RB30 is done :w00t:Here`s a few of R32 caliper`s i have had rethearded to 14mm series2 bolt`s just have to get some line`s sorted & will fit then up & see if these`s are any better then STOCK 2POT`S,,cheer`s chuckie
Edited by chuckie
......mmm rb30......
anyway.....the gtr brakes will be heaps better, easier to find pads and rotors for, and cheap. I went with the G4s because I wanted new all round but before that I had the GTR gear on mine.
You'll love em, I certainly like the improvement on my car. I also just fitted a UAS Brake stopper and that has made a noticeable difference to hard stopping, e.g. brake pedal feels a bit firmer.
Only thing I am missing now is some steel braided lines. How are you going to approach brake lines Chucky? I have thought of going to somewhere like race brakes and getting a custom set made up but I am thinking if there are a number of people after brake lines it might be worth organising a group buy.
I got a quote from Maltech in March last year for replacement S1 lines - $495 inc GST & postage.
Couldn't justify it at the time, but now I've bought a set for the Z the Stagea has moved further up the list.
lolz
Im already running Maltech braided brake lines, so will simply use an adapter piece to make 2+2 fit together
plus I already have a set of larger slotted rotors that I grabbed a yr ago for $50
got these Panoz 4-pots off ebay, searched Panoz Wilwood !! I paid $150aud delivered.
as good a deal as brembos surely
with pads being 120 deliv its under $300 so far
rims are BJR Grafic 17x7.5 +38 with 5mm spacers
definately going to make them fit -
just had a quick search
www.wilwood.com
They look nice
http://info.wilwood.com/BrakeKits.aspx?yea...&model=350Z
They do a kit for 350Z, so they will fit M35's??
They do a kit for 240sx(our 200sx with out a turbo) as well. . . hmm wonder if they will fit the C34
Looking on ebay.com, looks you can new calipers for $165us each?
Need to do a bit more research
these were used / made for Panoz Racing and used on the rear of a nascar (?). guy had 4 sets, they went real quick.
love my ebay
will use my trusted engineer shaun at BoostWorx DynoTuning & Engineering to fit.
edit: could be outlaw 4000-series
more research coming up !! lol
p5.pdf
Pretty flash mate
324mm with 33gtst calipers only JUST fit under 34GTT rims, can't say about those other calipers but I would imagine it would be pretty close.
Aftermarket 17's with more offst would probably fit bigger but not the 34GTT rims.
Yes.
Kit part numbers for M35 (Z33) are
NS01 (front) - SL6 BB Front Hat Kit
NSR01 (rear) - FSL4 BB Front Kit
Brake lines are required;
220-7016 (front)
220-9197 (rear)
I like them alot!
  • 3 weeks later...
z32 brakes are the same as R32 gtst brakes, depending on the series. they are a 4 pot caliper but run on a smaller 280ish mm rotor. i'm sure you could get them to bolt up, most of the calipers share the same mounting hole centers, but i dont think they would be much of an upgrade. best go for some R32 GTR/R33 GTST brakes, or even better R34 GTT's
Edited by QWK32
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
