the main things you can do for a brake system are:
1 New pads - the complier is required to do this by law. perhaps he forgot temporarily?
2 New discs, or machine discs flat - Discs are 150-300ea depending on model, and machining generally costs around $40 per side.
3 New Fluid/Bleeding - Costs about 100-200, replaces the fluid in your brake lines and removes any water and air bubbles that may have collected.
Assuming 1 is done, if the brakes thrum/pulse you probably need 2, and if the pedal is long and it doesn't stop well try 3. There are other more expensive things that could be wrong (of course) but they are the main place to start.
Complier has to give you a road worthy car, although any additional work on top of pads, tyres and fluids will probably cost you.
According to the modification list ,brake fluid was replaced but not pads. Is there a document I can download to see what must be changed on my stagea m35 series 1 ?when I go back to the compliance shop I need to have something to support my views.
  • 3 weeks later...
Hello Stagea owners,
I have been meaning to ask this for a little while now. I have a series 1 (1997) RS4 and the handbrake(footbrake?) light on the dash is on almost all the time. I didn't get a owners manual when I bought my car so I was wondering if this was a warning light to let me know I need to replace the pads, or is it more likely to just be a wiring fault?
cheers
Brett.
cheers
Brett.
check your brake fluid level
Anyone know if there is a difference between the 4pot callipers on the front of R34GTX in comparison R34GTT?
I wish to put R34 4pots up front as i'm aware they have the 14mm bolt/mounting holes which makes life easier to fit on a S2 Stag.
I've got a pair of 4pot callipers from a 97 Stag 'apparently' (bought via auctions) with the 12mm bolt/mounting holes and they look
just the same as any other 4pot skyline callipers.
Advice?
s1-stageas rb25 never had 4-pot brakes.................. 2-pot single sided fronts, 1-pot rear calipers
4-pots would have come out with the 260RS. Probably R33 gtst calipers. Do they have sumitomo written on them (r32 gtst) ?
righto, so R34GTT 4 spot fronts fit S2 stagea fronts without modification. now my question is, R34 GTR brembos are a direct upgrade for a R34 GTT, now if i assume correctly then given the right wheel combo then R34 GTR brembos are a direct bolt up to our S2 Stageas? can anyone tell me if the wheel clearances are the same or the GTR brembos are slightly bigger? (my wheels have "brembo clearance" but still unsure on fitment)
ditto on my s2, 2pot front/1pot rear.
yup, sumitomo. i should have mentioned that. so r32 i have?
I had same thought. my assumption is the r34 brembo's would bolt straight on. bigger disc diameter. brake line fittings maybe different?
They're on my wishlist, just out of the budget at the moment.
there is lots POSTED ON BRAKES,you will have to RETAP BOLT HOLES,
the S2 brakes have 30mm more PAD the 4 pots,
with z350 Slotted rotors & brake stopper,you will find there as good as 4 pots
i shall look at Group buy on 1 piece briaded lines,very soon,
yeah i know, i've gone back and forth through this thread many times to check whats been done etc... seen some repeated questions :)
been umming and arring what to do for a bit.
was just curious when i saw a pic of r34 gtx & r34 gtt front brake calipers, they looked the same. but gtx non turbo yeah?
maybee someone put gtt calipers on their gtx? i'd expect gtx maybe 2bot like stag if stock?
when i measured the holes (12mm) the other day on the 4pots i have, i thought oh no i'd have to retap or do the spacer thing. which i dont really wanna do. so may have some 4pots up for sale shortly :) as i hunt for some others.
prefer to get some r34 series 14mm calipers nissan/brembo, bolt straight on then get the lines sorted. (if i go that path)
i vaguely remember a engineer / replicar car builder advising there is a rule/law that the brakes, seatbelts, emissions etc...
when modifying have to be from the same year of manufacture or newer. hence im not gonna use these 4pots i have.
keeping 'mods' in the eyes of insurance/law within their stipulation so i dont stooge myself :).
want it to be a sleeper.
re: 'the S2 brakes have 30mm more PAD the 4 pots'.
Always noticed the difference in surface area and always been thinking, is 4pots worth it.
Cause the standard 2pots have more surface area, therefore require less force to brake.
As opposed to the 4pots which have less pad area, but being 4pots use more braking/clamping force.
(i remember some old science class stuff about surface area and pressure)
So it's probably 50/50 on the benefits/time/effort over all in changing to 4pots i have also been thinking, given pad materials
good discss/lines etc.. The 4pots probably more effective on the lighter skyline.
Have also been thinking, stay with standard calipers, get dixcel slotted rotors (being direct fitment).
Get some decent pads, braided lines, brake stopper and be done with.
Next thought, why have people been upgrading (besides track cars/towing loaded 7*5 or tandem trailer etc..),
the standard brake setup pretty good. But even saying that, I've towed a tandem behind a stock r31 with a 1982 vc commodore 1300kg,
then another time with a 92 hyundi sonata 1200kg on the trailer ... no issue at all. even checked the chassis later being anal and all with cars :)
The brakes were fine, paid attention to stopping distances etc... all good.
I've been on some very very twisty country rd's quite often, which were 100km limit with 40kmh warning signs/bends
which have come up on me a bit quick at times, and standard setup never let me down, that in summer also with a few
hours driving already passed. Not blowing trumpet, but also i use gears effectively and set car up for corner as been taught in
a couple defensive courses which makes a big difference + teins/r34 rims/good tyres also add to overall handeling/braking.
(some of those defensive driving courses i advise to do if u havent, if not for the fun factor especially if in your own car, pick up good tips)
tooo many thoughts on the matter/options with brakes amongst other mods... ($$ tats me outa here)
Edited by Stagea_Neo
when your chasing e36's down twisty roads you will see yourself wanting the bigger brakes
34 gtt brakes give you an extra 20mm of rotor diameter so the 4 piston calliper also has more leverage on the brake rotor as well as clamping power
they are also thicker so you have better heat absorption and dispersion too
RDA slotted 350Z rotors, greenstuff pads, master cylinder stopper.
Does pretty well (obviously it doesn't stop like my 32) but the main reason for upgrading to slotted rotors and better pads is so you can stand on the pedal more often without fade. Stock brake setup does alright, I could make it kick ABS in but it was really only good for one hard stop and then they were rooted until everything cooled down.
Will be trial fitting chuckies 1 piece braided lines on the weekend and we are working on a solution to use the larger Stagea calipers with a bigger diameter rotor (such as 324mm 33gtr).
i put slotted rotors, EBC greenstuff (6000?) pads on my xtrail that had more go than standard and go driven harder than a 4cyl should. dont get me wrong they were 100% better than standard and it pulled up heaps better but my rotors had a blue tinge and surface cracks like crazy. i wish i had a bigger rotor option but only thing i found was a 2k 6or8spot front upgrade from k sport.
if were talking about more surface area then why not "upgrade" to drum brakes? its not only about friction material surface area but braking efficiency etc. i rekon fitting the brake stopper is a good idea but pad and lines may be a great upgrade for some but insufficient for other depending on how the car is driven or what the car is used for.
at the end of the day its driver preference, what might be the ideal setup for some might be "this drives like shit" to another. fair call?
@chuckie - why would brake calipers/hubs need to be tapped out when for s2 C34 the R34GTT calipers (NOT R33 GTR) are a direct un-modified fit? (apart from rear backing plate and possibly using the skyline brake lines). and if the R34 GTR brembos are a direct bolt on upgrade for R34 GTT then why not a direct fit for S2 C34?
if someone then went for R34 GTT calipers all around and then went for some slotted rotors and EBC pads to suit their application, would they not be better than the standard brakes with the same pad/rotor combo? (genuine questions)
Hi Taylor,
ok Drums only good for ONE STOP then HEAT is Problem lol.
i guess you may have Miss read ,
R34 GTT are same as Stagea S2 14 mm bolts,
R32 & R33 are 12mm Bolts as you would have seen in MY MOD photos,
Brake LINES Skylines are not as long as Stagea Lines so why use OLD RUBBER LINES that don`t fit .
If you look at PAD size all Skylines are 130mm pads,
Stagea S2 are 157 mm,
with few simple mods you can make Stock setup as good as any 4pot caliper mod R32 & R33 calipers,(caliper only mod)
R34GTT have lager Rotor but not PAD.
If you think Rubber lines are Good then you should look at what happens when pressurized they go Ridged,
R34GTT upgrade ,well spending $1000 + on that setup,if you thing that is worth it maybe,
I so far have spent $450 on my current setup,
FRONT END New Z350 Slotted rotors, Black stuff pads,
N1 air ducts,brake stopper,
Rear Gtr 32 Calipers,Slotted Rotors,
Black stuff pads braided lines,
I have got a set of Braided lines to go in Front but these are like stock using hard line over Hub,
I am also sorting out Dogbones to RUN 324 mm rotors with Stock S2 Caliper,hope this might be soon
Cheer`s Chuckie
Well all i can say on this subject is ! 324mm rotors r33 calipers with the spacers from unique . I will not be going back to standard ! The only way i will be going from here is trying braided lines which i all ready have, and then brembos ! The setup i have now is nothing but better than standard . The r33 caliper may not use all the disc but braking is much better in my opinion. And unfortunately my wagon is not driven kindley at any time unless my wife is driving ! Will let all know brand and price of my braided lines soon .
If you look at PAD size all Skylines are 130mm pads, Stagea S2 are 157 mm
Pad size is irrelevant... Amontons' 2nd Law of Friction: The force of friction is independent of the apparent area of contact.
Larger pads can often be detrimental to performance as they're harder to modulate and increase the null zone. That's why the rear of most cars (which is the unloaded end and harder modulate) these days with fancy electronics are trending towards smaller pads, on larger rotors. Most cars now come with larger rear rotors than front rotors for this exact reason.
  • Like 2
IT is in a 1700KG WAGON & one built in 1998, with 298 mm Rotors ,just wonder off & play please .:domokun::stupid:
  • Nope 4
    • More assembly going on, with all sorts of "bolt right on bro" scenarios going on here. Smartly, PTV clearance was checked. And I say smartly because it turns out that the intake was 0.009" from piston meeting valve. This is 0.23mm. This is very not okay. A fast meeting was facilitated between engine builder in Australia and engine builder in the USA which was actually incredibly helpful and constructive actually, various ideas thrown around to get around this issue including: 1) Retard the cam timing which would have brought the exhaust valve closer to meeting piston (it was 0.065") which was uncomfortably close to begin with, and change the cam profile making it 'laggier' 2) Much larger head gaskets which would reduce compression, but half the point of this was to increase compression. 3) New set of pistons ($$$$$$$$$$$$$$$$$) 4) All of the above 5) Get ghetto The concept is you get sticky sandpaper and stick it back to a valve, slightly larger than the valve you/I'm using, like say from a LS3/rectangle port head. You now have a very super advanced flycutting tool to modify your pistons in your block. Then you install it in your head, and attach the other end of the head to a drill. Then you just replicate your valve smashing into a piston with your spinning drill.   This is the result. Repeat many times. It is strongly recommended you have some kind of fixed stop when doing this for extremely obvious reasons because if you press too hard then you're well into apocalyptic repercussion land. The minimum clearance on the intake valve is now 0.075" this is still in the "Too close to be really comfortable" and into "It should be fine" land. Supposedly in the real world the clearances will be slightly bigger. Guess this is what happens when people push envelopes for N/A engines instead of adding boost! Time to move onto the new, upgraded, higher ratio roller rockers from Yellaterra, all tapped and threaded with a stronger bolt for better stability. Very nice. Lets see how they fit. For f**ks sake. Time to bring the grinder out for these aftermarket, machined and CNC'd heads. Looks like the new, beefier rocker from YellaTerra has gone from Bolt on part to "Bolt on part". Well, lets see how this bolt on crank scraper and windage tray goes then, shall we? There actually is more clearance than they specify for this thing, but seeing it all move as you check it is terrifying when you see it all so very very very very nearly hit things. But after all, this is what the item is designed to do after all and actually did bolt on perfectly and have enough clearance to everything and some very clear and direct instructions. So +1 to Improved Racing I suppose. As above with the windage tray on. Photo of breaker bar wonkiness for added lols. Next up: Oil pump/front cover/water pump/sump and then it's time to actually install the heads, pushrods, head bolts, valve cover gaskets and such is all there and ready to go. (except the oil pump bolts which were previously longer for more clearance with the previously perfectly installed double row timing chain). There's definitely a sense that someone other than us has been here before and done everything perfectly, or at least considered it and came up with working solutions. Perhaps the previous cam was 6deg advanced to avoid PTV issues with the milled stock heads? In any case when I attempt to sell this stuff the buyers are going to be very directly informed.
    • my catch can is pretty easy to empty but it overflows due to the blowby/crank case pressure etc. max I have drained is ~600ml even with a ~2.3L capacity. So it is not just about having to drain it out its the mess it makes down the firewall and under the car and rear passenger tyre from the overflow oil being blasted by screamer + air in general. Ending up on the ground cleaning the oil up and having oil on your arms when everyone else can chill and watch the other sessions gets old fast
    • Yeah - the secret learned a long time ago is that the RB likes to belch oil out the covers, and/or starve the pump because it drowns the head in oil, because the upflow of crankcase gases from piston blowby comes up through the oil drain holes in the block and prevents the oil from flowing back down. The external vents from sump are about creating an alternative path/much more XS area for gas flow to decrease the gas velocity up through the oil drains and allow the oil to get back down. So, it's not about pressure at all. It is about flows - gas up and oil down - or when it's not working, gas up and oil not going where it is supposed to after it arrives at the top, except out through the cam cover vents. And regardless of whether the catch can is vented to air or vented to the turbo inlet, it must still be vented because a sealed system would blow out the crank seals, or something equally bad.
    • I just used a can that's easy to empty after every session and pour it back into the fill hole. Takes about 40 seconds when you have 40 minutes between runs :p I don't see how changing any catch can stuff will reduce pressure if the system is sealed. And if it's vented - Does it matter where it's vented with regards to overall pressure?
    • Welp, too late already committed to the cam cover breathers to be welded on. I did think about adding a catch can in line with the drivers side sump breather as a phase 2 along with a drain to the sump on the original catch can but with an inline ball valve so I can have it closed if needed.    Likely a single breather would have been enough but I think I’m overcompensating to hopefully not have to empty my catch can and clean up oil over flow every session.    out of curiosity has anyone actually measured crank case pressure before and after various mods? I’m considering adding a sensor for science
