Hey all.. Just went in to my local Autobarn for some hose and enquired about brake pads for my S2 C34 Stagea and "it just so" happened that they had a set of Bendix ones, the are DB1170's but looking here I think they may have given me the wrong ones? Can anyone confirm if DB1170's are right for a 2000 model Stagea?
1. Return shitty pads
2. Order remsa pads from GSLRallysports (sp?)
3. Fit remsa pads
4. ?????????
5. Profit
Yeah I took them back, turned out to be bloody 200sx pads or some shit... Just gonna order some cheapy QFM ones from gsl
Remsa is only $10 more than the qfm hpx and are supposed to be a bit better again
Either way you can't go wrong
Dust?
As far as I'm concerned; if brakes don't dust up, you can't really expect anything to special out of them.
They are a bit dusty, nowhere near as dusty as TRW/Lucas pads, but if you had white wheels; well, you wouldn't anymore... Having said that; it just washes off with soapy water.
In any case, with slotted rotors, you have to expect some dust.
That's why my wheels are painted Toyota Tungsten, and not white. :ninja:
Ah. I remember when I had white wheels.
But alas, that was two weeks ago, when I last washed it.
  • 3 weeks later...
For some of you who had fitted an R34gtt calipers and rotors(front only) on to their PNM35/NM35, can you tell me how much you had to grind off on the bottom steering knuckle/hub to clear the rotor? to stop it from rubbing. When I trial fitted my calipers and new rotor from r34gtt it rubs on the dust shield and the offending knuckle/hub. And when I tightened the wheel nuts on the rotor I can still slightly spin the rotor, so this indicated to me that only a few mm will need to be gring off? Obviously dust shields will need to be trim as well.
They clear the knuckle fine; it the dust shield that is the issue.
I cut the dust shield away almost completely; if you rotate the wheel with everything fitted you'll get a witness mark on the dust shield. Cut a couple of mm inside the mark.
Either that or measure the id of the back of the rotor, and transfer that dimension onto the dust shield. Cut accordingly.
Either that or measure the id of the back of the rotor, and transfer that dimension onto the dust shieldy. Cut accordingly.
Yeah I rotated the rotor and it scored the dust shield nicely so i can cut nicely around it. The new rotor will also need to be skimmed before it gets fitted on. The r34 back ID rotor is alot shallower compare to the stagea rotors. It just Im not sure how much is needed to grind off the knucke. Will it weaken it? It seems ARX-four maybe has a different offsets or knuckle/hub assembly?
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
