  On 06/10/2012 at 2:40 AM, krzysztof said:
cheers lads! went with the 34 setup ($250 for callipers and pads), just need some rotors now.. i am rather lazy right at this point in time do i need to mess around with lines?? ;)
No, I have r34 front and back using the standard stag lines, the rears needed some different clips to attach but not sure exactly as it was done for me.
  On 05/10/2012 at 10:29 PM, pipster11 said:
Go the 34 brakes on a s2 if you can
Someone asked about gtr rears, should be fine but you'll probably need tin snips to trim the backing plate/dust shield
thanks for that, anyone have any insight into upgrading the master cylinder going from stock s1 brakes, to 33 brembos?
I haven't tried that exact swap, but would not expect you need to change cylinders
I've run 33 gtr and g4 8 spots on my gtr without any bias issues. I've run 32 gtr and g4 8 spots on my stagea without any bias issues.
In the end, it is the total piston area that matters, the 32 and 33 gtr have about the same size pistons, the 8 spots have 8 very small pistons, and the stagea has 1 very large piston. you could always calculate the areas but I think you won't have an issue.
awesome, thanks heaps mate.
I changed my S1 brakes to GTT brakes with no issues. Later I put R32GTR brakes on the rear (essentially the same as GTT) and 330mm D2s on the front. I then put a BM57 master cylinder on which just means that with a larger area there is less pedal travel but more effort required. It would probably have been fine without the change.
sweet, if i have any issues with it, ill swap it out, but i figured it would be fine, just wanted to check with knowledgeable people.
Correct me if i'm wrong, but from what i have read online, 34 and 33 brembos are the same, and therefore gtr34 brembos should bolt up to my s1 all the same?
Edit: will a 324mm rear rotor and caliper off the later model gtr34's bolt up the same? or will i need dogbones to suit the bigger rotor?
Edited by HousewifE
trying to be a tightass and avoid spending 450 on dixcel rotors i spent 600 instead! :wacko:
250 - r34 gtt front callipers
80 - rotors and machining
130 - shim kit from nissan
140 - hpx pads and 1L brake fluid
Sorry to be a pain guys, I've read through countless pages of what Rotors will suit the S2 C34. From what I've gathered, the 34 GTT rotors are a direct fit, but I'm looking at going for some slotted rotors. I've read that shaving down the OD of DBA brakes for the 32GTR and 33GTST will work, but that information was posted a few years ago. Does anyone know of any direct replacement slotted disks for the S2?
Again sorry to be a pain, I need to get them replaced ASAP.
Thanks
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
