Stagea Brakes
hmm, are you saying that I could purchase a set of Slotted Rotors built for the 34GTT as long as I buy a set of Calipers as well?
I'm kind of looking to buy a full set of brand new slotted rotors that are completely interchangeable and require minimum to no modification to fit.
If anyone has part numbers or recommended Rotors, I'd appreciate it.
yep that's what u can do.
the dumb ass guys here in Perth not hear what i said, i have a s1 not a s2 so the rear is 265mm some people piss me off.
now i have new 295mm rotors i cant use.will have to take them back glad i not take them out of the plastic but check it all first.
dose any1 know of a rotor with all the same specs as a skyline but only 265?
Edited by whitenight27
Ok can u guys help me with info for fitting r33 rear brakes to my s1. Need to know of all the bits needed?
If they are the same as GTT brakes: calipers, pads. rotors. Need to trim the backing plate. You may need to pull the olives out of the calipers to convert to banjo fittings for the brake lines or vice versa.
  • 4 weeks later...
right guys cant seem to found the answers im looking for.. Ive got a rs4s stagea ive got r34 brakes to suit.. question is about braided lines will r34 braidlines work? notice each cailper have three seprate pieces.. some i see online are only two piece?
A little while ago i replaced my brake pads all round due to the fact that the rear left was metal on metal (the rest still had a fair bit on them but changed them anyway so they were all the same), while it was off i noticed one of the bar guide things in the caliper was a tiny bit bent. Hoping it wouldn't be too much of an issue i just put them back on. Turns out now it is an issue as the same corner has worn down again. rather than just find a new/secondhand caliper, i thought it might be a good reason to do a brake upgrade all round. Can anyone confirm the below for me? also should i be looking for new stuff or just go secondhand? and also will this be a reasonable upgrade or would i be better off going something bigger/different?
I have converted my S2 to all R34 gtt spec brakes (F+R) in my garage.
The rear dust covers needed a little trim around the caliper area, i just used tin snips, a file and pliers to bend the daggy bits.
From memory the front dust covers were fine.
The diameter of the rotors was close enough to just bend them a little where they touched.
I had the rear R34 soft lines but they dont match the Stagea at the chassis side where they join the hardlines.
I was able to pop the ferrule out of the caliper with a self tapper on both sets of calipers and use the original banjo fittings.
The rear banjo bolts needed abut 3mm taken off its length as they still bottomed out, took my time with a hack saw and a file and no dramas.
Also there is a fitting block bolted to the back of the rear R34 caliper that connected the soft line to a short hard line into the ferrule fitting.
I couldnt find a way of making the blocks work so they're in a box under my work bench with all the old Stag brake parts.
I have left the brake lines as per Stagea spec,
I used all the original Stag caliper bolts but they were the same as R34 ones.
The pad was dragging due to the bent pin, mine was the same when I bought it. I have no idea how one pin can bend but it seems to be common. You could simply straighten the in a vice using something soft so you don't mark it, then grease it up and re-fit them.
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
