The rotors are RDAs, they are OK, imo not the same as DBAs but thats my 2c.
I have NFI about the pads, never heard of them, but heavy duty means sweet F. all. Seems like a fine setup for a daily car, but its not going to perform at a high performance level.
All good chaps. Ordered a set of RDA non brembo 350Z Touring slotted and grooved rotors and some RDA heavy duty pads to match.
$250 all up.
Not a damn thing wrong with the RDA H/D pads.
For the $35 per end I paid for mine a couple of years back they did a damn good job.
You're right about RDA's but only compared to 4000 series and up.
My understanding is, they're basically a trade servicing rotor; whereas DBA 4000 & 5000 series are a much higher carbon content, and hence much tougher & resistant to repeated heat cycling.
On a street car (which is 90% of Stageas) the RDA's are up to the job.
The Tuners Group is selling Porsche calipers for ~$611 each. Apparently they will fit DBA's 350mm 5000 series discs.
Still an expensive package, but getting comparable in price to some of the BBK's out there. Performance would have to be OK I'd imagine.
http://www.tunersgroup.com/porsche_brakes.html
  • 4 weeks later...
I thought it was worthwhile consolidating all the Stagea brake stuff in one place.
Series 1
Front Pads - Bendix Premium 1398BP
The generic Bendix code is 1398, the last 2 digits are the pad type (BP = Bendix Premium).
There is an alternative being 1250, this pad is 14 mm thick and the 1398 is 15 mm thick. It seems 1398's are hard to get at times, so 1250 is a good alternative. I found a set of Lucas Premium pads in the 1250 part number. They are the TRW manufactured, European spec material, so they should be OK.
Front Disc Rotors - DBA 4909
These are the same as the S14 200SX
DBA have these in stock currently
Posted Image
Rear Pads - Bendix Advance 1144 or Ferodo XL 1144XL
As for the front, the generic Bendix code is 1144 the last 2 are the pad type.
Posted Image
Posted Image
Rear Disc Rotors - I am going to try DBA 4908 (R32GTR), modified by maching down the OD by 30mm, all of the other dimensions are the same. This is a rather drastic reduction, I will have to check them for cracking for a few weeks before I sign off on their suitability.
DBA has these rotors in stock currently.
Posted Image
Series 2
Front pads - Hitachi HP63H FF
The guys with S2's haven't found a Bendix equivalent yet, but I am sure they will post it up as soon as they do.
**edit by mods** this information is not correct as the offset is wrong for S2 stagea
Front Disc Rotors - DBA 4963 (R33 GTST) modified by machining down the OD by 6mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
**/edit**
Rear Pads - The generic Bendix code is 1399
Rear Disc Rotors - DBA 4908 (R32GTR), modified by maching down the OD by 5mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
I will post up some pictures of the front rotors and the pad install as I proceed through it
Sent from my GT-I9305T using Tapatalk 4 Beta
I'm not sure if this has already been mentioned, but has anyone checked the Bendix online catalogue lately for Stagea pads? They have pads for all now just having a look at this link.. except gtr.
http://www.bendix.com.au/catalogue?manufacturer=Nissan&model=Stagea#
I was looking around for pads as i got that squealy reminder from the rear shims today.
Edited by Stagea_Neo
nice find
best to take the p/n and order elsewhere tho
for the price of Bendix ultimates, you may as well pay a few more $$$ and get QFM HPX or Remsa pads from GSLrallysport
Buy they already know the numbers for Stageas anyway
have had my stagea awhile now and just had some lenso 18" fitted today to replace the crappy stocks
and my brakes definatley need replacing, she's mainly an everyday driver.
what should i be looking at for brakes? not wanting to spend over $300 ideally, but ive no idea on prices.
Look at the post directly above yours; it holds the answers you seek.
  • Like 1
This has probably been covered.. but hey, worth the info..
I wanted a bigger set of brakes on my S1 M35, but without the big $$ price tag.. I need to tow my race car. ( under 1200kgs).
I found the 14mm caliper bolts hard to get a set of 4 spots for. I rang around a few wreckers & found that the R34 GTT calipers had the same bolt size.
The only mod i needed to do, was to remove the existing backing plate. The R34 GTT kit , bolted straight on. Even the GTT brake hoses fitted up.
Great easy mod for $350. I fitted hawk pads from http://www.vsport.com.au/ .. Been to Phillip Island & back with ease..
Hope this helps..
Hope this helps..
Yep, a few of us have gone this way; great value, also looks completely factory.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
