Slotted, drilled or dimpled, they all reduce disk surface area to cool the pad at the expense of the pad which wears quicker. More surface area provides stronger braking force.
Personally I would be fitting solid disks for the road, and then chose the correct heat range pad for your driving style.
  • 3 weeks later...
My wife has decided she's not a fan of the PNM35's brakes and is talking about upgrading them. Far be it from me to go against my wife's wishes...
Given it'll most likely be a budget upgrade, my best options are modded R33 GTR or 350Z non-Brembo, correct? I'll probably be restricted to 17s still, it's hard convincing an accountant to spend unnecessary money on a depreciating asset. Sigh.
Maybe if someone has the time and knowledge (I have neither) they could knock up a summary post for each model?
Can't edit my last post but I found this elsewhere, which seems to answer my question:
http://www.sau.com.au/forums/topic/288150-m35-brembo-brake-coversion/?p=5725446
Just in case I can't convince her to splash out $4K on brakes for a family wagon, anyone got feedback on the RDA slotted and dimpled OEM replacements? I'm after performance over looks. Also, I see people have used EBC Reds, anyone have other/better options? I haven't bought decent brakes in nearly 10 years, fml.
Edited by Hertz Donut
Honestly Matt, just grab a set of R34 GT-t Sumitomo 4 piston fronts (with rotors) can usually be done for around the $300- $350 mark.
They literally bolt straight on; with some trimming to the dust shield behind the rotor.
These are a huge step up from the stock front brakes; I don't reckon your missus will want for more.
Obviously having a greater selection of performance oriented pads will help here too.
Throw in a set of QFM HPX pads; around $90. They bite well from dead cold and run up to around 550deg.
I don't rate EBC car brake pads at all; they're overpriced, and poor performing.
RDA rotors are fine; they also do a couple of budget performance pad compounds if you're trying to keep costs down.
They will look good, and still fit behind most 17's; (the stock Stagea 17's might need a hubcentric spacer if you insist on staying with them).
  • Like 2
R34 gtt brakes are as rare as hens teeth here in tassie only seen three r34gtt's here aswell
In the last 12 months I bought 2 complete sets of front 34gtt brakes with good discs for $200 each. 240 delivered from interstate. These where purchased through skyline spares in Sydney. They had shit loads of them and where clearing them out.
I haven't found a set of R34gtt front brakes yet and in the interim I've gone for slotted and dimpled rotors (f&r) and EBC pads (they were in stock, QFM weren't) red on the front and green on the back - difference to standard brakes is night and day and the rotors haven't warped and the vibration has gone. Boiled the fluid coming down the Clyde the first time and went to a higher temp fluid. The brakes still aren't as good at the bottom as they are at the top and you have to drive accordingly. I understand the R34 calipers won't fit under 18inch ARX wheels - what sort of wheels will I need?.
Yep I have new RDA dimpled and slotted with 350Z Brembo calipers from a wrecker.
Rotors were $360 delivered(front and back), callipers were $1000, QFM HPX pads for $110 and $600 for calliper service and fitting.
I've done only around 100km and there still is noise/vibration from the slots.
It does seem to be going away though.
I wish I went solid rotors- cheaper too
I'm happy with the improvement of fitting EBC reds to my stock front brakes and have had no issues (EBC got a bit of a bad name with warped and worn discs but have since improved their compounds). I'm currently rebuilding and painting front GTS-t callipers I picked up for $150 with discs. Just waiting on some 14-12mm spacers for the mounting bolts and also painting some 18" wheels to go on.
just have your local fitter and turner spin some up on a lathe
That's what I'm doing, just waiting on my engineer to get through his Christmas/New Year backlog. :rant:
Here's the R33 GTS-t calipers ready to go on (once I put some pads in them):
So R34 GTT front calipers and discs literally bolt on to an M35?
Same size bolt, no spacer required?
Disc fits on 4WD M35 Hub?
Brake line bolt on without modification?
Only Dust Shield needs to be clearanced?
Matt
Matt
Hey Matt; yeah straight on.
The only thing you'll need to to do is either remove the double flare seat from the bottom of the brake line hole, or shorten the NM35 Banjo bolt.
The dust shield will also need clearancing; it fouls the inner edge of the rotor once you lock everything down tight.
  • Like 1
Matt
I will be doing this, possibly this weekend or next. Hoping the stock 18 inch autech axis wheels clear the caliper. Otherwise spacers will become my best friend.
The double flare seat..is this the olive in the brake line connection point in the calliper? I threaded a screw into the olive to pull it out. Sounds the same as the R33 GTST calliper install but without the hassle of bolt spacers.
Sounds like the best bang for buck.
Thanks for the quick reply.
I have 20"s so clearance is not a problem =)
Edited by BoostdR
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
