Picked up a brand new set of R33 front rotors, cross slotted DBA Kangaroo paw discs. $50
already have a set up front, so will machine down and put on the rear :(
are you sure that will work, most rear rotors i have seen have a deeper offset than fronts to accomodate the handbrake shoes.
Aswell as a bigger hub to accomodate the drum for the handbrake shoes.
Probably better off machining a stock rotor down so the hub becomes a hat and run 2 pieces rotors.. :(
the R33 caplipers have a different sized bolts that bolt them to the hub, the S2 stagea ones are too big for the R33 brakes, from memory the stagea ones are M14 and the R33 M12.
to bolt the R33 GTST calipers to the S2 stagea hub you'll need to get some longer bolts that suit the R33 calipers, as the R33 bolts aren't long enough to get through the thicker stagea caliper mounting plate on the hub. you'll also need some sort of bush to help locate the M12 bolt in a 14mm hole, i am going to turn up a bush on the lathe when i finally get around to doing it, but i've heard of someone using a small piece of copper pipe.
i haven't looked into the rotor side of things yet, one thing i can tell you is the stagea rotor cant be used with the R33 calipers. i have some R33 GTST calipers in the garage and had a look one day at what was needed to put them on, i also have a S2 RS four V. and thinking of it now the only thing i didn't check was to see if the brake line fittings were compatible.
mods could you please sticky this part at the start of the thread so s2 owners know whats involved with upgrading their brakes to 33 calipers?
cheers. Bradd
  • 3 weeks later...
i'll be doing this shortly with a set of R33 GTS-T brakes (front and rear) .. the main reason why i'll be doing it is not only to decrease brake fade but more so for cosmetic looks. the look of the skyline brakes are heaps better than the standard stagea ones. but thats just me.. :D
will the front set fit a s2 stagea with R33 GTS-T Front calipers without the bung removed??
if so then the full set pictured should fit ( there for a R32 gtr), i believe the standard R32 gtr brakes are the same as the R33 GTS-T
Brake Pads.
http://cgi.ebay.com.au/STAGEA-WGNC34-TURBO...p3286.m20.l1116
P.S thats for a full set... Front and Rear.
I bought some of these off ebay, only paid $200 delivered though. putting them on next week
Front pads - Hitachi HP63H FF
The guys with S2's haven't found a Bendix equivalent yet, but I am sure they will post it up as soon as they do.
**edit by mods** this information is not correct as the offset is wrong for S2 stagea
Front Disc Rotors - DBA 4963 (R33 GTST) modified by machining down the OD by 6mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
DBA have these in stock currently
**/edit**
ok... to replace standard s2 front rotors andpads i shall order these yea? and just get the rotors machined down 6mm?
**/edit**
DONT BUY R33 ROTORS!!! READ THE WARNING!!! DIFFERENT OFFSET!!!
GENUINE ONLY OR EX JAPAN!!!
READ BACK A FEW PAGES AND YOU'LL FIND PEOPLE HAVE R33 ROTORS MACHINED DOWN AS PAPER WEIGHTS OR DOOR STOPS!!!
MODS=We need this thread cleaned!!!
New sticky on stagea brakes please, 20 pages of useless/misleading crap!
S2 Guys with r33 rotors machined down and using as door stops, s14/r32/z32 rotor is 280mm O.D
just machine a bit more and resell as r32/s14 rotors!
any M35 boys thinking of brake upgrades?
the M35 brakes are terrible too undersized
The brakes actually aren't that bad if you use a good pad.
I am using QFM A1RM at the moment. Great price & performance. No brake dust (which is a must for me) and they seem to wear well.
Talk to Jetpilot1986 about them.
Otherwise, if you have the money, get the Z33/V35 Brembos. They bolt straight up.
I believe that Andy65b and Jetwreck have put R33 brakes on their M35's... Still waiting for a thread on it...
I first upgraded to Hawke pads in the standard brakes which was a good improvements. And no dust.
Then upgraded to R32 GTR calipers and slotted rotors with Bendix Ultimate pads. Much more bite in the brakes now but not tested for fade after series of heavy braking.
It is a fairly easy upgrade with only minor modifications required.
  • remove dust cover behind caliper. (could be trimmed if you want to spend more time)
  • Grind back the bottom of one bracket about 3mm for clearance of the rotor
Other than that it is the same as doing on any other Stagea.
Cheers
Andy
I just did mine too. Had to change the wheels to accommodate the 4 pots but kept to 17 inch rims. Calipers and rotors came off a TT. Wheels maybe the r34 look like my old newer ones but more rounded. Brakes sweeter now. I think V35 infiniti in US was recalled over its brakes.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
