fitted rear r32 gtr discs, rebuilt calipers (with speed bleeders) and r32 gtr (front) braided brakeline
fittted front r32 gtr rebuilt calipers, cpz bracket, 324x30mm 350z track rotors drilled, with stagea (front) braided brakeline
pads are qfma1rm all round
mags needed to clear are 18x8.5"
on the r32 track car Im putting on the stagea rear rotors, stagea rear braided line, stagea rear calipers & pads
on the front goes the wilwood superlite calipers & matching braided brakeline & pads, plus a new set of dba 4000 rotors Ive got sitting here
Dixcel Part No.'s for Series 2 Discs WGNC34.
I'd be pretty sure they be straight swap, OD/Offset/Thickness same.
PD-Normal Disc
SD-Slotted Disc
HD-Heat Treated Disc
HS-Heat Treated Slotted Disc
The rrp price is there too converted from yen (currently 76.6)
DIXCEL 98/8~01/12 WGNC34
Front Part No. 321 2013
pd 218.41
sd 327.62
hd 341.16
hs 450.34
Rear Part No. 325 2018
pd 218.41
sd 300.23
hd 354.81
hs 453.99
is that per rotor or per pair (assume pair)?
can anyone confirm whether brakes are the same between RS Four and RS Four S (i would assume so)?
actually, according to the Dixcel website, i believe the part numbers are (for S2 C34):
FRONT - 321 2013
REAR - 325 2016
(as opposed to 325 2018)
i am sourcing pricing from japanparts, and will pass on the details
apparently all S2 are the same, but S1 are different
for S1 C34, i believe the part numbers are:
FRONT - 321 2019
REAR - 325 2018
cheers
Edited by Stooge007
*** Series 2 Stagea Pads now back in to stock ***
Apologies to all those that have been waiting patiently on the back order list, we now have stock of the S2 Stagea pads to suit both street and track.
Front HPX $119
Rear HPX $79
Front A1RM $179
Rear A1RM $179
- HPX is a Bendix Ultimate/EBC Green/Project Mu B Spec equivalent performance street pad.
- A1RM is a Bendix SRT/Ferodo DS2500/Project Mu HC+ equivalent street/track cross over pad.
Any questions, or to order, just swing me a PM, or give us a bell on 1300 884 836. Free shipping when you order front and rear together, or else $8 per axle set individually.
Regards,
Greg
Fitted some RDA954S rotors and some Greenstuff pads on the weekend.
The RDA954 rotors definitely fit s2 RS4V, anyone having fitment problems, make sure the calliper is clear of the rotor (use a screwdriver for leverage, make sure the rotor is nipped up with a wheel nut so it is held tight) before tightening the calliper bolts.
actual dimensions for ROTORS series 2 1999 rs4s
FRONT -
diameter 290mm
height 48mm
centre 68mm
minimum thickness 26mm
brand new thickness 28mm
REAR -
diameter 292mm
height 63mm
centre 68mm
minimum thickness 16mm ( couldnt remember exactly what measurement was here but pretty sure this was it could be 14)
brand new thickness 18mm ( couldnt remember exactly what measurement was here but pretty sure this was it could be 16)
so far from my searches nothing is exactly the same.
and from what i could see on dixcel japan website is that there are 4 or more different type of rotors between series 1 and 2 some going right through all models so it is possible that some suggestions that have been posted will work on some cars and for others it wont so make sure u do ur research b4 u buy or take some of the advice on here
If series 2 RS4S is the same as series 2 RS4V, then the 350Z rotors will fit.
i have had it at a brake specialists for the last 2 days and they said they will not be right 1st major difference is the thickness of the rotor od is out and height is slightly out on the 954s rotor
BUBBA just let them get on with it,
CAN`T HELP SOME so let him get fed BULLSHIT
Whatever you want to get fed is up to you, I fitted them on the weekend.
Agreed, I'm over it.
Anyone found a solution for dogbones to fit 324mm GTR rotors yet? :cool:
With 33gtst/32R calipers yes, I have a solution that *should* work but haven't tried it yet. I have a set of dogbones that fit on non-4wd front hubs but they hit the lower ball joint on 4wd hubs. I have another set that are supposedly off a z32 that offset the caliper as opposed to the other ones which rotate it.
With stock calipers, not yet as I need to solve the offset issue.
Edited by bubba
meh...
must have been the small print on screen.
here's a screen capture for all to refer to.
FRONT - 321 2013
REAR - 325 2016
FRONT - 321 2019
REAR - 325 2018
cheers
** S1 Stagea Pads Now In Stock!!! **
Hi all, we've just received our long awaited first shipment of QFM Performance Pads to suit S1 Stagea!!! Available in both compounds, QFM HPX (Bendix Ultimate equivalent, fast street) and QFM A1RM (Ferodo DS2500 equivalent, fast street and track). Prices as follows:
HPX Fronts $119
HPX Rear $119
A1RM Fronts $179
A1RM Rear $179
Shipping is free when you order front and rear pads together, or else $8 per axle set individually!
Any questions at all just let me know!
Regards,
Greg
Fitted up new front slotted rotors with new pads today and if it doesn't rain tomorrow I will fit new rear slotted rotors and pads then bleed brakes allround.
Which rotors did you use on the front, RDA 954S? I've had my set machined down and will be fitting them tomorrow.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
