Have you guys called up these guys:
Brake Distributors of Australia
(07)5569 2207 or 0414 868 555
They sponsor the SAu QLD club and are DBA dealers. I have dealt with them before for my old 33's brakes and found them great on price, but I got a discount for being club member of course :)
OK I phoned them and asked them for a discounted price, they said $235 each rotor?? Doen't seem that cheap to me.
Sk is there still going to be a group discount happening??
I am working on a Group Buy, brake pads, braided lines and rotors. But it won't be all off the shelf parts, some parts will be tailored to my engineering requirements. In particular the brake pads as I have found NOTHING off the shelf that meets my expectations for hi CoF, no noise, good fade resistence and low dust. I have the compound worked out, just waiting for prototypes to test.
Thye are a couple of weeks away at best.
:) cheers :)
  • 1 month later...
  • 4 weeks later...
Brakes are still great, bit too much dust. Now that manufacturers are back from Xmas close downs hoping to try one of my all time favourite compounds. It's the taxi, ambulance, police car, fire engine compound, they last well, good heat and low dust with an OK CoF.
Update shortly.
:P cheers :(
Edited by Sydneykid
  • 1 month later...
Query;
It looks like I might be getting a larger set of front brakes (calipers & rotors) in the future.
Has anyone replaced the rear Stagea brakes (calipers & rotors) with those from the front of the Stagea?
Does this sound feasible?
Tangles :D
Asked a mechanically minded mate at work and the answer I got from him was........
Depends if all the mounts were there for the fronts on the back.
The disc should go on, not sure about the caliper, you may have to fabricate something up?
Also when you are making any chnages to the brake system, make sure to make sure that the brake bias is still appropriate, or you will go around locking up your backs all the time :D
Yes, thats a top point about bias, WD.
Got some info from SK on the matter, I hope you dont mind me posting this info for all Stagea members:
"As you probably already know, the rear rotors have provision for the hand brake drum brakes. I think that will stop you using the front brake callipers on the rear as the pads (and the calliper itself) would hit the drum in the centre of the rotor. Plus I don't think the calliper mounts are the same front and rear, so some adaptor would be needed."
Edited by Tangles
  • 3 weeks later...
I have some news for everyone.
SOOOO, as I do, I have been reading through FAST and checking out what parts are from where.
So get this.
My car is built 97/08. Now, there was a model change in August 1998 and one thing they changed was the rear brakes (was checking to see if SK was right the rears were R31 pads)
So, my car, being a newer revision, has R34 N/A rear pads and Nissan Cima Y33 front pads.
So I did some investigation and found that..... cars pre-97/08 dont actually share the same brakes as me. According to FAST, the rear brake pads for the cars pre-mine are R33 N/A, R32 N/A and a heap of others, not R34 like mine and the front pads are the same until 98/08
Just keep that in mind when making any brake kits SK, as if i had bought them, i would have found out there was a revision in the brakes a little to late ($$ wasted)
Though, we could still confirm this by actually testing it car against car.
So get this.
Isn't August 1998 a Series 2?
Mine is pretty late in the Series 1 build, remember it had Series 2 rear door.
:D cheers :P
Edited by Sydneykid
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
