bigger booster to suit the 4 spot front brakes on the WGNC34?
Stock setup would probably have been fine - BM50 m/c but I have fitted a GTR one BM57 which will have slightly less travel but require more effort. Auto booster should be fine.
So is it worth getting a brake stopper for the M35? They're not exactly cheap...close to $200 for a big hunk of metal...
i was talking to scott about it.. actually doesnt seem to hard to make one.. maybe we will..
Get someone to push on the brake pedal, while you look at the firewall flex behind booster; I reckon it would be a worthwhile addition.
It could likely be done for less; might have to take a look.
Does anyone know if there is any difference between a Stagea Series 2 and a GT-t brake master cylinder.
They list different part numbers but both appear identical and are both BM50's?
I have searched previous posts from Darrin after his GT-t brake upgrade but I haven't found any information on potential differences.
Does anyone know the reason for an early DTV (disk thickness variation) on M35 brakes? Apparently a few people have had this problem already...
Thinking of putting new pads, machine the discs and check that the brake hub is not causing this...
Has anyone done all that and had the problem happening again?
Thanks in advance...
I'm trying to decide whether to replace all my rotors with slotted ones or just get them machined. They've got enough left in them to just get them machined I think, and the rears need it badly. I've got HPX pads sitting here ready to go in, was going to try and do it all at once.
Why Waste MONEY doing that on Rear,
i did mine & couldn`t tell difference in stock to GTR setup ,
with fronts just get Sloted rotors & braided lines good pads & BRAKESTOPPER,
you spend $300+ on calipers & another $300+ on Rotors ,& still need to pads LINES & brakestopper ,so $10000 on brakes lol.
i spent $500 doing all mine & VERY HAPPY ,
Fully appreciate what you're saying, but I priced up a new caliper and pads and for not much more I've managed to find some R33 GTST brembo discs, ferodo pads(both with about 1000miles use) and good used gtst calipers. I've already got a 330mm front discs conversion and DS2500 pads with R32GTR calipers. I was never expecting a great increase in stopping power from the rears but every bit helps.
I bought mine from a group buy but I can't remember who organised it.
According to the Cusco website they list the R33 same part number as WGNC34 but different from WGC34 (2wd) so R33 one should fit.
http://www.cusco.co.jp/en/pdf/Brake%20master%20cylinder%20stopper_nissan.pdf
Pretty sure I sent you the UAS stopper Bob.
I'm looking at getting new disks for my car, rather than seeing if I can machine the standard ones.
Just wondering what other people are running?
GSL supply RDA and DBA rotors, and looking at DBA, probably in either slotted or cross drilled.
Obviously the more you spend the better performance you're going to get, but I think with most things you get to a point where spending more money isn't worthwhile on a road car.
I've always heard that cross drilled rotors are a bad idea for street use, but DBA say this is no longer the case, and they've found the same or increased pad life with their new cross drilled XS rotors.
Like to hear other peoples experiences, although I'm pretty sure any decent slotted rotor will be fine.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
