I'm looking at getting new disks for my car, rather than seeing if I can machine the standard ones.
Just wondering what other people are running?
GSL supply RDA and DBA rotors, and looking at DBA, probably in either slotted or cross drilled.
Obviously the more you spend the better performance you're going to get, but I think with most things you get to a point where spending more money isn't worthwhile on a road car.
I've always heard that cross drilled rotors are a bad idea for street use, but DBA say this is no longer the case, and they've found the same or increased pad life with their new cross drilled XS rotors.
Like to hear other peoples experiences, although I'm pretty sure any decent slotted rotor will be fine.
I have the slotted RDA rotors and QFM pads. The car stops so much better now.
Cost around $600 from GSL
Hopefully I make it to the next SA cruise if you want a look.
DBA are also cheaper.
Prices as follows:
RDA Front Std $79 each
RDA Rear Std $67 each
RDA Front Slotted $249 for the pair
RDA Rear Slotted $219 for the pair
OR
DBA Front Std $105 each
DBA Rear Std $77 each
DBA Front Slotted $159 each
DBA Rear Slotted $135 each
Prices as follows:
OR
U meant RDA's are cheaper right?
I was too tight to get the DBA's...:pirate: especially when everything costs more just because its "brembo"
sorry you are right...
I did not spot the each at the end...
Edited by FHF
I can confirm these 350z 324mm rotors (with dogbone caliper adapter) fits the S1 without many issues
http://www.conceptzperformance.com/Cart/description.php?II=882&Car_Type=300&UID=20110706225202121.45.157.163
a bit 'dodgy brothers' in the sense the dogbone is bolted on and caliper bolted onto the dogbone, but Boy do they work well.
tested at the track and stood up well to the braking pressures applied..... cut a few seconds of my previous best time as well.
http://www.conceptzp...2121.45.157.163
with which callipers?
Edited by pipster11
You need R32 GTS-T calipers; The ones for 280mm x 28mm rotors. If you use R33GTS-T or R32 GTR (non Brembo) you'll need a 342mm(ish)dia rotor.
I have a set of similar brackets and I'm investigating the possibility of using a reduced O.D. 370Z rotor, but I'm not convinced the rotor will sit satisfactorily inside the caliper to allow a full wipe of the brake pad without further mods (rebalancing rotors, modifying brake pads).
anyone know how much for some r34 rotors?
310mmx30?
tossing up weather to machine mine or get new ones
Are they on the min thickness? It'll be between 29mm & 28mm at a guess. Only around $40-$60 to machine a set of rotors if you remove them.
Link; http://www.dba.com.au/product-search
DBA 42304 4000 Series Standard 310x30mm; $244.21
DBA 42304SL 4000 Series 6x6 Slotted LH 310x30mm; $300.56
DBA 42304SR 4000 Series 6x6 Slotted RH 310x30mm; $300.56
DBA 42304XS 4000 Series XS (Premium Gold painted Slotted & Cross Drilled); $350.66
I'm sure you could do better than this dealing with GSL Rallysport or someone else.
Or; http://www.ebay.com....=item20b977f5c0
Or; http://www.ebay.com.au/itm/Nissan-Skyline-R34-GTT-Slotted-Front-Disc-Brake-Rotors-/120739706075?pt=AU_Car_Parts_Accessories&hash=item1c1ca5b4db
Edited by Daleo
cool beans, that last ebay listing is pretty cheap
i'll get the verniers out later
also, r32 and z32 rotors and callipers are the same but the z32 ones are alloy instead of cast iron and a fair bit lighter so probably worth getting some z32 ones
I swaped in a set of 34gtt calipers and rotors a couple of weeks ago. Front and rear rotors and calipers, machined up and installed with new pads for under 5 hunge... they go straight in, just make shure to get the 34gtt hard lines for the front calipers- that way you can use the stag soft lines. I used 32 rear lines.
Great upgrade for a heavy wagon. I wouldn't bother with anything smaller as an 'upgrade'.
Super easy swap.
Cheers
Jsutin
310mmx30?
Hi mate,
Prices as follows:
RDA Std $159 each
RDA Slotted $289 for the pair
DBA 4000 Series Std $159 each
DBA 4000 Series Slotted $159 each (yep, same price)
DBA 4000 Series XS $235 each
Regards,
Greg
Yes but will needed to have mods done ,
I did one for BUBBA ,& have same type on mine but modded different to his,
So everyone knows, I got a cheap one off ebay for an R33 GTST and it fitted straight up with no mods at all required:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=370447688978&ssPageName=ADME:X:RTQ:AU:1123
So it might just have been the type you had chuckie.
http://cgi.ebay.com....E:X:RTQ:AU:1123
Yes ,
i have a TOMEI,
:cheers:
uniqueautosports have locally made BMC stoppers made here in Sydney by Bosnjaks. They are also an option. I ran a group buy on them a while ago.
If there is enough interest I can probably get some better pricing on the stoppers and the brake air deflectors.
http://www.300zx.com.au/ look under braking. They fit R33, R34, Stagea S1/S2.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
