Oops, when i ment model change i ment 97/08, the month my car was built.
So what fluid?
There is only one Castrol SRF, but I don't use it in road cars. It is almost impossible to flush all of the old
fluid out and I don't like mixing silicon ester and polyglycol fluids. I prefer Castrol Response Super Dot 4, it is the best polyglycol they make.
:( Cheers :D
Isnt it a bad idea to put DOT 5/5.1 in DOT 4 cars as one absorbs something from something?
Anyway, ive ordered some slotted rotors from Bursons, getting the rotors for $180 each which I think is a pretty damn good price.
Going to order some Endless SSS pads if i can through the groupbuy running now here on SAU.
No rotors in stock, so they are being made. Will take 2 weeks.
So I will let everyone know my progress in future. I am also going to buy a home made brake cyl stopper from YahooJP, will ALSO let everyone how i go.
For now, my rear brakes do not concern me as in the end, they are just rears. Lets see what some new pads, rotors and fluid does to the car. AP/Brembos might just be a little too much overkill on a 95% road car.
  • 1 month later...
Hey Gary,
Just tried to install some new SSS ENDLESS pads + DBA rotors (part numbers you gave me). Had a few minor issues.
Anyway, there were some clearance issues and the pads couldnt fit over the rotors, so I just installed the pads on the std rotors (in goodish nick anyway)
Now, when I tried to compress my two pistons, one of them didnt go as far as the other (only tried installing disc on one side) and hindered my pads fitting over the discs (which are quite fat anway). Does that suggest that it needs to be rebuilt?
The standard stagea brakes are not bad once you put some good pads to them, I found out I had LUCAS pads in there, I thought stock nissan pads were a little too dusty! I will be staying away from LUCAS though now as they do have a terrible heat range.
Also, bedding in. I basically did about 20-30 medium pedal effort 50-10km/h stops, but seeing as I am using the stock rotors anyway, they will just bed themselves in next time i take her for a spirited drive no? I didnt get smoke or anything, this subject seems to cause some division among everyone. Do you always bed pads?
Cheers,
Alex
Hi Alex, how did you "compress the pistons"? I use a G clamp, centre on the pad and the back of the G on the rear of the calliper, then wind the clamp on. Nice even pressure, no side load on the piston. If you used the "screw driver/lever method" you will find that's your problem, with a large single picton sliding calliper its is very hard ot get even pressure. If you don't have a pair of G clamps (you only need on but they sell in pairs) pop down the SupaCheap or Bunnings, they are $15 or so for the small size you need.
The next trick is to open up the bleed nipple before you compress the piston. This means you are not trying to force brake fluid all the way though the pipework and back up into the master cylinder.
If you still can't get the pistons all the way retracted then it's time to service them.
Lastly, what thickness are the brake pads? They need to be 14 mm, you might just sneak 15 mm pads in there but 16 mm won't fit.
Cheers
Gary
They were pretty meaty pads, thickest ive seen around before.
I used a special tool, it was like a plate with a big long screw thing with a "cup" on the end. You put the cup in the piston, then the plate pushes against the other side of the caliper and compresses the piston. I tottally removed the caliper and broke it into half to install the new pads. That includes undoing all the hydraulic lines.
Also, you experiance uneven pad wear on the pads correct? When i removed my lucas pads, they were more worn on one side than the other (i guess a side effect of a single sliding)
I guess its time for a service/rebuild. Ill also find out the thickness of the pad material.
Also, do you bed in pads if you dont have new rotors?
Thanks,
Alex
Hi Alex, a proper calliper piston compressor, excellent. I did get slightly uneven pad wear, but not side to side ie; one pad did not wear more than the other. Mine had a tiny bit more wear on the leading edge of each pad. Which is common on sliding calliper. Uneven pad wear is usually a sign of a sticking piston or sticking slide on the calliper, so it doesn't equalise the pressure on both pads.
The piston should go back in far enough to be basically flush with the calliper. The piston should not "stick out".
Cheers
Gary
ok peoples ive been thru the whole thread and still cant find some decent info on the series 2 brakes we have got the series one sorted by the look of it .but us guys with series 2 are gunna be desperate for some help here. hey guys im no flamin genius on theese matters and your going to have to forgive my ignorance but i dont want to spend a fortune on endless pads or go thru the heartburn of trying to get nissan genuine if someone has found a better setup like u have with the series 1.i know mark is searching also and desperatly needs new rotors as will i by the looks of things .so come on guys lets put our heads together here. thanks in advance guys i know i wont be the only one that benefits here.
What exactly is it you are after?
Brake fluid - Castrol Response Super Dot 4, it is the best polyglycol they make
Front Disc Rotors - DBA 4963 (R33GTST) modified by machining down the OD by 6mm
Rear Disc Rotors - DBA 4908 (R32GTR), modified by machining down the OD by 5mm
Rear Pads – 1399 in any Bendix compound
The only thing I haven’t found an aftermarket/heavy duty part is;
Front pads - Hitachi HP63H FF
If someone wants to send me a pair of front S2 pads, I will see what I can find.
:P cheers :P
:P cheers :P
thanks mate ill try to get u a set of fronts
  • 3 weeks later...
Series II front brake pad and rotor replacement under investigation as I type (2 fingers). Will hopefully have some initial info, with photos later tonight. Now do not go getting all excited this info is preliminary as I still have a little bit more to do before final set up and testing is completed.
I have found a set of brake pads which, with a small amount of grinding, should seat very nicely in the front calipers. As can be seen in the first image, the pad is fractionally too long but by machining the tang and lower shoulder back 3mm @ both ends it should seat correctly. The pad (brand 'X') is common, and you should be able to source it from just about anywhere in varying degrees of quality.
The rotor is in fact a DB4963. SK has previously identified this rotor as the one to use with a small amount of machining (6mm) from the diameter. A trial fitment today showed the rotor did fit, with caliper in position and no machining was done. However it is a close fit and until testing has been completed no comment or recommendations can or will be made. (SK if you are reading this - machining may still be required).
The only issue noted to date is that the DB4963 does sit in a little further than the original rotor and may foul on the caliper. There is only about 3.5mm difference between the two caliper dimensions. Once the pad modification has been completed and fitted I will review the rotor/caliper clearance.
I would like to have this completed before end of month. If not, then end of financial year stocktakes, accounts etc will take priiority.
As soon as any further developments have been made I will post it up.
Ok guys just sent my car for compliance today to kamikaze and i asked them about the brake pads issue that im worried about.
The guys said that if the car came with an aftermarket brakepads they are rquired to be change to the specific pads that have a specific part # 41060aa393 (front) and rears are part # 44060ab085. Does any of the aftermarket brake pads have these part #s? i doubt it. If so i will most likelt get ripped off for having to change to a genuine brake pads (brembo) remember people i have the 260rs. SIGH!! 1k gone. let me know people
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
