God how effing hard is it? Ordered some DB1399's through repco on wednesday said they'd have them thursday but somehow ordered in front pads for the stag... so then ordered them again and DB1144's turn up... Some people can't get anything bloody right.
  • 3 weeks later...
due for front pads for my s2, found bendix now has a listing for them db1696
might be worth adding this to the first post in the thread to make it easier to find
all the c34 and m35 stagea pads can be found on the bendix website here
http://www.bendix.co...an&model=Stagea
I used them in my 180sx and with its weight of only 1250kg, going through the hills it would get severe fade and end up with no brakes at all. They where also dusty as hell.
Put in a set of stock Nissan pads and heaps better compared to bendix ultimates.
i have bendix ultimates. nd i dont get any brake fade through the hills, how ever they do squeal like hell. they are very dusty. only thing i would recommend doing is putting dot 5 brake fluid in if u have dot 4 atm. however i do also have R34 brakes all round. but shouldn't be much difference interms of brake fade.
Well i have DOT 3 in at the moment and is says on the fluid reservoir to use DOT 3 only. I just put some Bendix General CT pads on the front to replace the (worn) stock nissan pads and noticed an immediate improvement in braking performance. They were cheap enough that I can replace them if they fail my expectations but I guess time will tell :thanks:
dot 4 exceeds the requirements for dot3
I've got the remsa pads on the front of mine (with r34 4 pots front and 2 pot rears)a they are lovely, really notice the difference coming from the r31
Dot 5 brake fluid should not be used on an abs equipped road car. It is silcone based and quite different from normal brake fluid.
Dot 3 is pretty much obsolete and can be replaced by Dot 4 or Dot 5.1 (as opposed to Dot 5).
yea sorry meant DOT 5.1, not DOT 5
That is really retarded. Why wouldn't they give DOT5 a completely different name, instead of having DOT5, which you can't use, and DOT5.1, which you should use? So easy to get confused...
:domokun:
Heya guys.. had a half decent read through the thread here but just need confirmation on a cpl things.
I have a s1 stagea with totally crap stock breaks. been offered some r33 gtst 4pots and slotted rotors for cheap.
1.they do bolt straight up.. Ie no need to drill the caliper mounts out larger/sleeve them?
2.stock brake master cylinder is up to the task of operating these 4 pots?
Edit. found the answers i was looking for other than one more question.
Will 33 brakes foul on my standard stagea wheels?
Edited by driftrx
Most sets of 350Z brembos seemed to be around the $600-800 mark when I was looking. Check out Japan then compare to here and the states.
Personally I'd be going the Akebonos if anything. SO sex, and by the time you add up cost of lines, rotors, etc, it doesn't work out too expensive.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
