apprently the 260rs brake pads are the same as the 33,34gtrs for the front and i would susprct th rers are the same. they share the same part numbers
of course they are :whistling: the brembos are r33 gtr items on 260rs's, and the r34 ones are identical but painted gold instead. so brake pads would be exactly the same :laugh:
beKW FLUIDS QIAE AHOULD I JUAT UAW dor 4 onwa or go for the dot 5?
Also i've heard that if we keep on changing different brand of brake fluid its not good for the rubber seals in the brake system is that true?
wtf does that say? :whistling:
one tip is to re-read your posts b4 u add them as typos just make it sooo hard to read
no offence it just shit me haha, take a look over it once u post to see if its readable :D
thanks mate
hd;ofn;sdffndsfbf/e34[8fdjcdsjb/sd :laugh:
Edited by CruiseLiner
soz my son was playing with me and got distracted.
Anyway what i mean is brake fluids are there much difference between DOT 4& 5?
I've heard also about if we keep on switching brands when we change the brake fluids it will screw up the seals? Can anybody enlightened me please.
As far as i heard from Race brakes, they said it won't damage your seals. Also any brand of DOT4 is the same.
The difference between the DOT4 & DOT5 is the Boiling Temperature. DOT5.1 have a higher temperature rating and of course it's a higher quality brake fluid than DOT4.
wtf does that say? :(
thanks mate
hd;ofn;sdffndsfbf/e34[8fdjcdsjb/sd ;)
f**kING GOLD!!!!
HHAHAHA
I had the same reaction. I started reading and thought, what the hell is he trying to say, LOL...
  • 2 months later...
  • 1 month later...
has anyone confirmed yet that the R33gts (DBA 4963) rotors bolt on to the s2 front with some outside diameter machining ???? the was some talk of them touching calipers, has anyone done this to their s2, or something different they can share.
What about R34 Gtt rotors and calipers on front and back, would this upset the brake bias significantly ? thanks
Edited by chook
  • 1 month later...
Hey huys im a little conf*cked.
i want new pads for the S1 had a look at that autospeedbits site and tried to work out from the selection list they have what i need for the front and back, but had no luck.
http://www.autospeedbits.com.au/resources/...BrakesList.html
here is my question:
are the pads on the front and rear the same as the r33gtst/gtr or the r32gtst/gtr.
sorry again but i have read this thread front to back and all i want is a descent set of pads.
thanks for any help in advance cheers again
Clint, I believe it's DB1250 for the front, and DB1144 for the rear, assuming you're still running the standard s1 brakes.
Unfortunately, they're only two-spot brakes on the front, and one-spots on the rear, as opposed to 4-spot F and 2-spot R on the R32 GT-R and GTSt, and R33 GTSt.
  • 1 month later...
So no one has found s2 stagea front pads yet,
I have spent heap of time trying to match up a set and the closest i came was a set of 'rdb 1439' they are slighltly longer and need some machining down to fit app 3mm per side.
The other day at work i was working on a 2005 subaru liberty gt i saw that the pad looked very familiar so i measured it ....157mm in length same as s2 stagea. So i will be checking this out shortly and hopfully it will put an end to all s2 stagea owners worries... :D
but if anyone else has a solution already please let us know...
and thanks
and thanks
ok it's not the 2005 subaru liberty gt but they are the closest fit as they are 157mm and only require alittle cutting and they will fit.
alternitively change to brembos GTR...or 4 piston GTS-T but yo may have to change the offset of your wheels or use spacers :P
R33's came with 16" standard. :O
its to do with the way the spokes are at the back of the rim, that determines if they will fit or not.
skyline brakes apparently need a 'high clearance' type rim, ie. one that the back of the rim is quite flat, or curves very close to the rim itself, not like alot of those rims that curve in to give them the 'dish look'
my rims only just clear gtr brembos and they are abit dished, but its the spoke design that allows clearance in the right area...
heres a pic of the clearance with my 17' rims... (i think its about 10mm max)
i find the brembos a great upgrade and very much worth the $$$ if u got reasonable horsepower and wanna stop safely :O
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
